586,121 active members*
3,657 visitors online*
    Feb 2008
    15
    drilling cycle for acramatic 2100
    Im use to fanuc controls and I'm having problems trying to spot, drill and tap on my cincinnati 750 with acramatic 2100 controls.
    I have 138 holes per part and I want to spot drill .05 deep then peck drill down .6 with a .110 drill. I then need to tap these holes with a m3x.5 roll tap dwon about .4. Can anyone provide the g-code for it.
    Nov 2006
    418
    Katsbobo,
    The Mastercam post I use posts the following (using just three points - you can modify for yours), and I've almost never needed to manually edit any code generated from this post file. If you have Mastercam 9 or X, let me know & I'll send you the post file for your machine (send me a private message with your e-mail).
    Hope this helps. You didn't mention any peck for the centerdrill, but I did add the peck for the .110 drill, and you may check the feedrate for the tap - I did a quick calculation. Also, I didn't use the rigid tap code (G84.1) because I don't know how well your machine works with that - mine does great.
    Regards,
    John
    :G90 G70 G40 G94
    (MSG, PROGRAM NAME -A2100)
    (MSG, DATE 08-24-08)
    (MSG, TOOL 1 - .1250 CENTERDRILL)
    (MSG, TOOL 2 - .1100 DRILL)
    (MSG, TOOL 3 - M3X.5 TAP)
    :T1M6
    N100M26
    N102G0G90H01X0.Y0.S1500M3M08
    N104M11
    N106A0.
    N108M10
    N110Z.1
    N112G81Z-.15R.1W0.F.75
    N114X.5W0.
    N116X1.W0.
    N118G80
    N120M9
    N122M26
    N124M01
    :T2M6
    N126G0G90H01X1.Y0.S1736M3M08
    N128M11
    N130A0.
    N132M10
    N134Z.1
    N136G83J13Z-.7R.1K.0500W0.F3.472
    N138X.5W0.
    N140X0.W0.
    N142G80
    N144M9
    N146M26
    N148M01
    :T3M6
    N150G0G90H01X0.Y0.S0300M3M08
    N152M11
    N154A0.
    N156M10
    N158Z.1
    N160G84Z-.5R.1W0.F66.319
    N162X.5W0.
    N164X1.W0.
    N166G80
    N168M9
    N170M26
    N172M02
    Mar 2013
    59
    Re: drilling cycle for acramatic 2100
    Quote Originally Posted by John_B View Post
    Katsbobo,
    Regards,
    John
    :G90 G70 G40 G94
    :T1M6
    N100M26
    N104M11
    N106A0.
    N108M10
    N110Z.1
    N114X.5W0.
    N116X1.W0.
    N118G80
    N120M9
    N122M26
    N124M01
    :T2M6
    N128M11
    N130A0.
    N132M10
    N134Z.1
    N138X.5W0.
    N140X0.W0.
    N142G80
    N144M9
    N146M26
    N148M01
    :T3M6
    N152M11
    N154A0.
    N156M10
    N158Z.1
    N162X.5W0.
    N164X1.W0.
    N166G80
    N168M9
    N170M26
    N172M02
    Hi
    I have mastercam X and post for cincinnati lathe control acramatic 2100 . but my post no is good for drill toolpatch.
    you have post for acramatic 2100 of a cincinnati lathe??
    thanks
    Nov 2006
    418
    No, don't have one for lathe. I don't have the mill anymore either. 8 years later, so lots of things have changed.
    Sent from my SM-G920V using Tapatalk
  1. Acramatic 2100
    By dmerrll in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-05-2012, 10:41 AM
  2. NEED ACRAMATIC 2100
    By nikolamkd in forum Cincinnati CNC
    Last Post: 01-12-2012, 09:53 PM
  3. Need help acramatic 2100
    By logger in forum CNC Machining Centers
    Last Post: 03-19-2011, 11:41 PM
  4. Acramatic 2100 hdd
    By Amtec in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-18-2009, 08:49 PM
  5. Acramatic 2100
    By mblazenby in forum Tree
    Last Post: 02-05-2009, 02:30 PM
