586,043 active members*
3,553 visitors online*
Page 3 of 3 123
Results 41 to 50 of 50
  1. #41
    1121
    Re: Bridgeport Heidenhain parameter lists
    bump
  2. #42
    Apr 2022
    Please can someone help I have a Bridgeport interact 412 tnc 355, the buffer batteries died and I have lost my parameters does anyone have a copy please?
  3. #43
    Jun 2011
    61
    Quote Originally Posted by landyfun View Post
    Have there , have you got the info you need ?
  4. #44
    Oct 2014
    9
    Helli everyone
    I desperately need the parameters for a Bridgeport VMC460/12 with TNC 2500B.
    Can anybody help?
  5. #45
    Re: TNC145
    thanks for sharing Gus, I have been viewing your post and you have a lot of knowledge on these Heidenhain. I have a problem with my R2C3 TNC 145. Please message me when you can.
  6. #46
    Is safe to use this one ? I have a Bridgeport VMC 800 with TNC 370 with no tool changer.
    I replaced the batteries but still appears replace batteries, is normal ? I replaced with the 3 AA
  7. #47
    Jun 2011
    61
    Hi Marco , did you turn off the machine and then changed the batteries ? If you did this your parameters are gone !
  8. #48
    the batteries were dead. i use the parameters and it worked but warning of tool change not in position because i don't have it.
    Now i have another problem, relay ext. dc voltage missing.... :/
  9. #49
    I've got the parameters working but now when I tell to the spindle start spinning the spindle just rotate some degrees to CW then some degrees to CCW and then it appear on screen Spindle Drive Fault. Can someone help ?
  10. #50
    Jan 2023
    4
    my milling C.N.C machine had lose ALL PARMETERS , IF possible send to me the parmeters( bridgeport vmc 500 with heidenhain tnc 370 cnc control) Tank tou ,
Page 3 of 3 123
  1. Heidenhain TNC 426 - Parameter / PLC
    By rajappa in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-09-2024, 10:39 AM
  2. Parameter for: HEIDENHAIN TNC 407 B
    By elhosseiny in forum G-Code Programing
    Last Post: 08-22-2009, 08:49 AM
