587,490 active members*
3,127 visitors online*
Results 1 to 12 of 12
    Jan 2007
    93
    RIGID TAPPING NOT WORKING
    In Fanuc- OMD Controlled VMC Kitamura make, Its parameter washed out after loading again, now Rigid Tapping not working. I have checked the G address it is getting activeted in ladder but spindle does not rotate after reading rigid tapping G & M code.
    Any help pl.
    Jun 2008
    5
    Hi is your spindle at stop before g code out put?
    Sep 2007
    371
    Check your option parameters 900's, maybe the one that activates the rigid tapping mode is not activated.
    GP.
    Feb 2007
    314
    here is parameters of my hardinge vmc1000 with fanuc O-MD controller.
    Rigid tapping works fine. Hope this helps you
    Attached Files Attached Files
    Jan 2007
    93
    Yes, Spindle stopped after reading G84 & M54, but start rotating very very slowely ( as open command wire ). Also traverse in vertical axis does not synchronised with Spindle rotation and as I release the feed knob, vertical axis come in rapid downward.
    Is there should be any Fixed cycle prog ( %09xxxx) in edit memory to perform the rigid cycle operation.
    If any body know, pl reply.
    Jul 2008
    rigid tapping needs an M29 S1200 code on fanuc
    Feb 2007
    464
    Quote Originally Posted by slickerater View Post
    Or G84.2.
    Stefan Vendin
    Mar 2007
    122
    You will want to make sure that parameter 5200 bit #0 for G84 is set to 1 for your rigid tapping. Also check your in-position width for rigid tapping parameters 5300 and 5301. These parameters are machine condition related they may have to be increased depending on Z axis vibration. You will not be able to detect this vibration visually or even through sound because it is so micro.
    Jan 2007
    93
    Dear All ,
    Thanks for your valuable reply.
    At last I got the fault. One of its door Limit sw intorlock input was missing when checked in diagonasis. Soldered the wire at M1 connector at i/o board & now it is working fine.
    Thanks.
    Feb 2006
    1792
    M29 S1200 is for rigid tapping mode, but how is direction of spindle specified. Is it through M03/04? Does it have to be given before M29 or after M29 or anywhere?
    Mar 2006
    107
    I also use that on 0M
    Sorry for bad english
    Feb 2007
    314
    Quote Originally Posted by sinha_nsit View Post
    spindle direction is controlled by tapping cycle. G84 right hand thread and G74 left hand thread. No need to call M03 or M04, spindle stop at M29 Sxxxx.
  1. Rigid tapping help
    By Genguy in forum Fanuc
    Last Post: 12-08-2015, 02:54 PM
  2. Replies: 24
    Last Post: 05-01-2014, 07:02 AM
  3. RIGID TAPPING NOT WORKING
    By rajesh_1355 in forum Fanuc
    Last Post: 07-22-2008, 02:14 PM
  4. Rigid tapping 0-80??
    By SIERRAMACHINE in forum Fadal
    Last Post: 01-16-2007, 06:21 PM
  5. Rigid tapping or tapping head
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 09-24-2006, 06:08 PM
