586,051 active members*
3,945 visitors online*
Results 1 to 12 of 12
    Aug 2008
    9
    CNC Gerber Sabre Router table 408
    I have been running the same router for 7 years and am now starting to get some problems.
    When I route letters it seems as if they are not joining up at the end of the cut for example a letter O will have a bump at the start finish point. This never use to happen and I have tried many diffrent things to fix this.
    Dose anyone know why this might be and how I can fix it myself ?
    any help would be great!!
    thanks
    29
    does the machine have stepper motors?
    It could be loosing steps, possibly look at bearings, shafting.
    HArd axis movement.
    Oct 2007
    Your lead screws are worn. I have replaced mine several times. I have a brand new Y axis screw for sale if you need one. I don't have my Sabre anymore.
    Jason
    Jan 2009
    6
    i have the same problem...
    Dec 2007
    16
    Hey guys.
    It's not necessarily a problem with the lead screws (I've run one for 10 years now without any problems). It could also be a malfunctioning encoder. I would check into this as well.
    Apr 2009
    This is the lead screw without a doubt replaced mine as well after encoder etc. and only then was everything running smooth. If you only cut to the front of the machine this is the cause of the wearing. Try cutting a test to the back of the machine and see what happens.
    Apr 2008
    4
    What is involved in changing the y axis screw?
    Is this something that a normal person could handle?
    About how long does it take?
    Thank you, Jim
    Jan 2009
    6
    no se si hablen espanol
    tengo una guia con fotos para remplazar el lead screw(y)[i have a guide with pictures for the replacement pf the y lead screws it someone need it let me know, and by the way i try diferent ways to fix that problem on my sabre but problem still, i think i will try to chnge the y leads screw...
    Sep 2009
    do you still have it? is it new? does the nut come with it? how much?
    email me thanks Dino.
    Sep 2009
    Oct 2007
    Yes I still have the Y lead screw. It comes with a new nut. Still in the original box and untouched. Let me know if you want it. Will take $400 obo.
    Jason
    Sep 2009
    jason,
    where are you located (zip code)? and can you give me the dimentions so i can check out shipping costs. thanks dino. and that screw is for a sabre 408 right?
  1. Gerber Sabre 408 help...
    By crackstar in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-19-2018, 01:29 PM
  2. How to cut jobs longer than the table using a gerber saber w/artpath
    By Cocoa Astros in forum Uncategorised MetalWorking Machines
    Last Post: 08-13-2008, 04:02 PM
  3. Running g-code on gerber sabre 408
    By precise graphix in forum G-Code Programing
    Last Post: 08-04-2008, 07:37 PM
  4. Gerber Sabre 408
    By Pasty in forum Want To Buy...Need help!
    Last Post: 07-21-2008, 03:52 PM
  5. Gerber Router III?
    By Zephrant in forum CNC Machining Centers
    Last Post: 09-17-2003, 05:58 AM
