Dear All,
I try to install mach 3 on two PC. I found the different response of two PC.
The first PC. (Spec. Pentium 4 , Board intel ,CPU 3 Ghz, Ram 1 GB.)
I install mach 3 on PC and place license file and then reboot my computer again. I open mach 3 and set everything on ports and pins ,motor tuning. When I try jogging , It has the signal from parallel port. Motor can response and rotate.
The second PC. ( Dell,Spec. Pentium 4 , Board intel ,CPU 2.8 Ghz, Ram 512 MB.)
I install mach 3 on PC and place license file and then reboot my computer again. I open mach 3 and set everything on ports and pins ,motor tuning. ( Same as the first PC) When I try jogging , It doesn't have the signal from parallel port. Motor can not response and can not rotate.Why ? What happen ? Who can know the root cause of this problem?
Hope for this help
Mongkol
