I've just started to play with madcam, on a real super simple part. First question how do you get the tool paths to show up? I check and the layers that they are on are visible, but no tool paths are showing up like in the video's on the mad cam web site.
Second question is, as you arc off the part, is their any way to get a bit of traveling past were the cutter originally started.
Once a tool path is created, is their a way to get back into the tool path to edit it??? Incase you made a mistake with step, feed speed etc.
Thanks.
