Hi all, I have just purchased a Mechatronics Bipolar 4 axis Stepper Motor Driver board (4x-0727 pcb model- says on back of board), and I need help hooking up my steppers and making the board work. I also need to know what voltage to give this board.
I am using 3 nema 17 Sanyo Denki Step-Syn Motors 103H5209-0440
The power supply I am using is an adjustable, up to 12v.
I have it connected to my comp by parallel with a female to female gender changer, as the board has a male connection. I have Kcam installed on the computer.
I followed the documentation that Mechatronics supplies, but no joy.
The motors buzz, but no movement.
I have read that even if I have the order of wires on the motor wrong, it will try to move, and thru trial and error, you can get the right sequence. Is this true?
Do I connect the center taps? Other sites I have read from say to connect them together, but mechatronics doc says dont.
all help will be appreciated!!
Joe
