586,106 active members*
2,919 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Poor mans XY table rails - would something like this be viable?
    Jul 2008
    139
    I'm forever trying to come up with ideas for cheap parts, I can source these quite cheaply....
    I was thinking certainly for the Z axis it should be ok (obviously removing the handle/arm & also stripping the rods & support from the base), but what about two for the X axis & two for the Y axis?
    I seek a cheap desktop CNC with a movement of about 12" in the X & Y axis.
    I guess it depends on how much 'play' they have (can't say - not seen one in the flesh), but I could possibly negate this by use of a custom arm with a roller skate bearing on it to press up against the rail.
    If they have any play in them, they'll probably bind, and you'll probably find that they flex quite a bit when used on a machine.
    Jul 2008
    139
    So how about a leg (with a roller skate bearing at the foot) attached underneath the middle section....this should help eliminate flexing & therefore binding?
    May 2008
    110
    One of the most important parts of one of these machines are the rails that the axis rides on, this is not a part to cheap out on. If they flex the machine will not work to any kind of accuracy.
    budP
  1. High Speed Machining viable for DIY??
    By scavenger in forum Open Source CNC Machine Designs
    Last Post: 10-11-2007, 01:46 PM
  2. Poor Man's Cutter Table
    By vladdy in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 08-19-2007, 07:48 AM
  3. poor mans book
    By dragons_fire in forum Mini Lathe
    Last Post: 01-21-2007, 02:17 PM
  4. Design of plasma table, high rails or low rails?
    By Apples in forum Waterjet General Topics
    Last Post: 12-18-2006, 09:21 PM
  5. Poor Mans Autocad solid converter
    By CAMmando in forum Mastercam
    Last Post: 07-17-2003, 02:10 PM
