586,096 active members*
3,775 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Cheap CAM for Bridgeport Interact 1 MKII TNC155
    Aug 2008
    6
    Smile Cheap CAM for Bridgeport Interact 1 MKII TNC155
    Hi everyone!
    I need some advice regarding some CAM software which will permit me to import DXF files ( and / or DWG) and which will operative with an old Heidenhain TNC 155 control on a Bridgeport Interact 1 MKII mill....?
    I currently use the Heidenhain conversational mode of programming and not the G code but as I understand, the TNC155 is also G code compatible.
    I would really like to be able to speed the process up a little as a lot of the work I'm getting now is small batch size and therefore the programming time(especially when stock removal and multi rad arcs are involved) contributes to a large proportion of the total job time.
    In actual fact, even a means of off-machine programming would be great so as I can prog. the next item whilst the mill is still running with the current item.
    Any advice would be very gratefully received
    Duncs.
    Feb 2007
    414
    Hello Duncs,
    Have a look at Dolphin PartMaster - www.dolphin.gb.com
    We have a range of products to suit your needs, and have post-processors that output Heidenhain plain language - L X50, Y50, R M etc.
    You can download a trial system from the website or call us on 01563 543989 for more info.
    Best Regards
    Andre
    Aug 2008
    6
    Smile
    Thanks Andre!
    I'll check it out today
  1. Interact Bosch servo drives for cheap!!!!!!
    By Interact77 in forum Bridgeport / Hardinge Mills
    Last Post: 02-02-2010, 12:29 AM
  2. Erratic behavior from Bridgeport Series 1 Mk2 with TNC155
    By dbcooper99 in forum Bridgeport / Hardinge Mills
    Last Post: 01-16-2008, 06:14 PM
  3. Bridgeport TNC155 with EMC2?
    By dbcooper99 in forum LinuxCNC (formerly EMC2)
    Last Post: 12-15-2007, 09:34 PM
  4. Interact 1 MKII 4th axis problem....?
    By DuncanRitchie in forum Bridgeport / Hardinge Mills
    Last Post: 08-23-2006, 03:05 AM
  5. Bridgeport Interact 1 MkII problem
    By sparsrus in forum Bridgeport / Hardinge Mills
    Last Post: 05-02-2006, 09:53 PM
