586,103 active members*
3,514 visitors online*
    Oct 2004
    48
    Exclamation chip load question
    were do people get this number? I am very new to cnc setup was an operator for along time now learning the setup and programming end of it.and are there any beginner formula's that are very valuable that some one could post for me any help is greatly appreciated.
    Apr 2003
    1876
    Chip load is the linear amount each flute moves as it passes thru the material. (How much material is removed by each flute). It is used in a formula to determine optimum speeds/feeds for a given tool in given material.
    PHP Code:
    ChipLoad x RPM x NumberOfFlutes InchesPerMinute of travel
    or
    PHP Code:
    InchesPerMinute x RPM x NumberOfFlutes ChipLoad
    It will vary from operation to operation, from tool to tool, from material to material, etc etc. Many tool manufacturers have a suggested recommendation. HAAS' newer machines have a calculated display on the controller.
    Here's some other formulae:
    PHP Code:
    Tapping FeedRPM TPI Feed (IPM)
    Thread PitchTPI Pitch
    RPM x DIA
    3.82 SFPM
    SFM x DIA x 3.82
    RPM
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  1. Does anyone make a chip conveyor that works?
    By bob1371 in forum DNC Problems and Solutions
    Last Post: 04-03-2013, 04:53 PM
  2. Cool little chip !!!
    By mannster in forum CNC Machine Related Electronics
    Last Post: 07-22-2005, 10:06 AM
  3. Question about CNCZeus
    By CNCRob in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-14-2005, 04:06 AM
  4. Spindle Speed & Feed Rates - Question
    By Moondog in forum DIY CNC Router Table Machines
    Last Post: 07-24-2004, 12:24 AM
  5. How can I up my feed rate ?
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 07-13-2004, 03:40 AM
