587,008 active members*
3,622 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Please help with an optic interupt switch
Results 1 to 8 of 8
    Apr 2005
    124
    I have been trying to get these optic inturrept switches going for a few days. I did some reading on google searches and such, but to no ivail. The photo diode side wors fine if I supply my own light. I am using the interupt on m lathe spindle.
    I tried using seperate power supply before I got a resistor set from radio hack. I have multiple pieces so it's not just one that may be dead.
    I am a little stalled here and any help would be great.
    24223
    What is the part number??
    Al.
    Albert E.
    Apr 2005
    124
    h21a1, I have 10 of these
    h22a1, I have only one and it is the mounted unit for my spindle.
    24223
    If it is just the emitter diode side not working, if using 5v supply for e.g. , taking a ~220ohm resistor from pin 1 to 5vdc and pin 2 to common, it should work.
    The max LED current is 50ma, so if using it on a higher voltage, use ohms law to be well in range.
    Al.
    Albert E.
    Apr 2005
    124
    oh crap math,I got into machining so I didn't need math. alright I will work on some more today. I am about ready to shelve it for a few weeks.
    as an after thought, at 50 ma max current, I can't see how the ones I've tested with are not fried ,so I will start with a fresh unit so as not to add to frustration.
    Thank-you
    24223
    If you did not use a resistor, they are blown for sure!
    Al.
    Albert E.
    Apr 2005
    124
    I am sure they are blown. I already tested a non touched unit and it performed flawlessly. It was drawing 10 ma, works for me. Now will be a slight task of mounting a good unit to the spindle. Different packaging may interfere with the assembly but that will be easy compared to this electrical adventure. But now it seems so simple.
    Apr 2005
    124
    thank-you very much for four time and assistance. It is working sweet all around.
    innovating the imitated
    http://www.youtube.com/playlist?list=PLT0IPUIWKw2G8Wdb6c291t_hPqyaEXCFq
  1. Optical interupt switch implementation.
    By owhite in forum CNC Machine Related Electronics
    Last Post: 07-26-2009, 10:27 PM
  2. Clock interupt or something?
    By thedoctor in forum Controller & Computer Solutions
    Last Post: 07-24-2008, 11:41 PM
  3. Looking for some Help Optic Lens
    By tklock in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-27-2008, 11:39 PM
  4. limit switch and home switch setup
    By Runner4404spd in forum CNC Machine Related Electronics
    Last Post: 12-15-2005, 02:58 PM
