586,655 active members*
3,489 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Where can i get metal stock for machining????
    Mar 2007
    10
    I found a few places but it is stupid priced. One place had a 7.5" square block of 6061 aluminium for $700.00. I've seen fancy billet parts that size for less than $100. Any info will be great.
    thanks
    Feb 2005
    376
    Honestly. 7.5"X7.5"X7.5" chunk of aluminum, if you only want one, I'd say you are not too far off base. Thats about 40lbs of aluminum. Now you have to find a place that stocks a 7.5" piece of square, or a place that stocks 7.5" thick plate. Either way, they have to cut it, plus stock it, and then sit on it until somebody wants it. Not an easy thing to find, and you will pay a premium for any thick material regardless of what it is.
    As for the "billet" part. I'm not sure exactly where you can get "billet", but last I checked its mostly a marketing ploy to get idiots to pay huge amounts of money for useless shiny crap.
    What you probably saw was a casting that used only a few pounds of material and was made in very large quantities.
    If what you need doesn't need to be extremely strong or absolutely perfect or need to be out of 6061, you might actually be better off getting a small guy to cast you a block. Lost foam would be perfect and I would guess you could get out of it for in the range of $200 or so. PM me and I can put you in contact with a small startup that could most likely help you, if a cast block would work for you.
    Quote Originally Posted by randyrw View Post
    thanks
    Jan 2008
    8
    check out the metal supermarket. maybe there is one near you. http://www.metalsupermarkets.com/
    Oct 2007
    307
    Quote Originally Posted by jimmytightpants View Post
    that place is VERY expensive. Ive bought alot from www.industrialmetalsales.com
    very good people to buy from.
  1. Best way to cut bar stock AL into slugs for machining?
    By SRT Mike in forum MetalWork Discussion
    Last Post: 09-25-2008, 07:21 PM
  2. where to buy scrap metal for machining in Austin, TX
    By rkovvur in forum Want To Buy...Need help!
    Last Post: 08-08-2008, 07:30 AM
  3. Where do you get your metal stock?
    By svarzaru in forum Benchtop Machines
    Last Post: 05-22-2008, 04:09 AM
  4. Replies: 0
    Last Post: 11-20-2007, 06:52 PM
  5. Stock setup and machining
    By tt_raptor_90 in forum Mastercam
    Last Post: 12-27-2005, 02:22 AM
