Hi Folks,
Very new to all of this and have been browsing for quite some time. I have a few questions that I'm hoping you all can shed some light on.
First, let me explain the reason why I've found myself here and why I'm asking for advice. At current I do ALOT of work with a local Basset Hound rescue here in Kentucky. -- I can hear you asking what that has to do with anything CNC. Well, if any of you have ever gone out to buy dog tags, you'll see they cost at least $5 each or so. Now, I can get the blank tags way, way cheaper. But I'd need a good, clean, easy way to engrave both sides of the tag with various info.. Since we're a rescue, money is very very tight. In fact, anything I do on this will be out of my pocket, which is almost as tight..
So.. Here it goes. What I'm thinking of doing is a very small two axis bed with a powered engraving tip that lowers via actuator to a set depth. The area that would need engraved would be at the most 2"x2" and the material would be standard thin die cut aluminum dog tags.
Is it possible?
I have several floppy drives from computers laying around that are either dead (access wise) or I just don't need. Since the unit would be so small I don't feel there would be a problem at all powering the two axis bed with the stepper motors inside. From what I recall, they're 6 wire steppers BTW, but I have to check before I even think of moving forward.
Software wise, I do not think I'd need anything in the CAD/CAM market area. I'm very tempted just to code my own and toss together a dead of Linux box to power and run it. But if there may be something out there that's either dirt cheap or open source, that'd be great and save me time when I do manage to get this up and running, if it's even feasible.
Come to think of it, I don't know much about CNC work or building my own machine, so I'll no doubt be full of questions.. I do understand sending commands to a controller via computer though.. My current "fun" project is building a set of animatronic eyes that I'll have interfaced with my main work comp.. Having spare servos on hand and a few Mini SSC's is useful.. Gotta do something with them..
So what say you.. Is it doable.. Will it be dirt cheap and be able to scribe legible letters on a tag... Think it'll be cheap? Am I wasting my time???
Thanks for any input..
Scott--
