In company where I work, we do a lot of perforations [see picture]. The problem is in the making of circular holes like this one on the picture No.2 [it has a 588 holes and program last for an 1.5 hours,way too much,wanna to reduce that time]. The problem is next, at the starting point, the router goes with feed 8 meters per minute, and rest of lines does not go even a 2,5 meters per minute.( The perforations are from diameter 20mm to 50mm)
My question is how to make in woodwop start point and end point with same feed?(try with tehnology macro but doesn't work ) Or I must use G or M functions in woodwop. If someone knows it would be very helpful. Thanx
The machine is Homag Optimat BAZ 322/60/K
Thanx
