586,060 active members*
4,027 visitors online*
Results 1 to 13 of 13
    Feb 2007
    1538
    Moldmaking on a Tormach
    As I learn CAD/CAM CNC it is impacting more and more on my little Toolmaking business.
    Here are some pics of 3D mould cavities in P20 steel.The CAM software is a bit basic but I get there! I am pleased with how accurate my Tormach is!
    Attached Thumbnails Attached Thumbnails cam.jpg   roughing.JPG   finishing.JPG   mould cav inserts.JPG
    Jan 2007
    93
    Would you mind posting some info about the feeds, speeds and endmills that you used?
    Feb 2007
    1538
    Quote Originally Posted by thackman View Post
    Hi TM - Sure - Solid Carbide ball mills: 8.0 dia rougher S3500 F200 step over 4.0, intermed 5.0 dia S4500 F200 1.0 step over, Finish 4.0 dia S4500 F200 0.1 step over. 1/2 hour with 320 grade oilstone to finish.
    Feb 2007
    1538
    The above is in millimeters or course - (for inch divide by 25.4)
    Jan 2007
    93
    Thanks for the info. Did you split the stock on a bandsaw after milling the cavities?
    Feb 2008
    180
    That is just rough cut right?
    Feb 2007
    1538
    Your welcome - The 'stock' was 2 blocks - clamped together - looks like one.
    Feb 2007
    1538
    Finished Mold
    Here is the finished mold - In addition to the cavity inserts above, I used my Tormach to drill the water holes, ejector plate holes, machine insert pockets, machine spigot ring recess, machine sliding core channels.
    Nov 2007
    151
    I don't know anything about mold making... what do you mean (and what is the process) of oilstone finishing?
    Ken
    Feb 2007
    1538
    Quote Originally Posted by apeman88 View Post
    Ken
    Mold cavities often need to be smooth - for product finish - or to allow part ejection.
    If the machined cavity is too rough, oilstone polishing is often a good option. Special soft bond oilstones have been developed for this task - wet with kero, they break down to the general cavity form - and cut quickly. Eg a Guesswein 320 moldstone is a common choice - and makes short work of this kind of job.
    I could have gone on to a say typically a 500 grit stone - then on to say 600 and 800 carborundum paper on soft wood - but it was not needed for this product.
    Nov 2007
    151
    Sorry for the next stupid question...
    How do you use the oilstone? Is it a polish? If so... how do you get into the cavities? Or is it a tool that can be used on a mill?
    Ken
    Feb 2007
    1538
    Ken
    Hi Ken - It is a hand held abrasive oil stone - have a look through the guesswein web site below -
    http://www.gesswein.com/catalog/home...TOKEN=62469490
    Nov 2007
    151
    Keen,
    Thanks for the link! I've always been interested in mold making but have no idea what is involved. I'll be studying! :-)
    Ken
  1. What is next for Tormach?
    By Chuck Reamer in forum Tormach Personal CNC Mill
    Last Post: 09-08-2007, 12:30 AM
  2. Moldmaking Expo 2007 Chicago, IL
    By bkobernus in forum Trade Shows / Webinars / Other Events
    Last Post: 04-15-2007, 08:59 PM
  3. Beginner moldmaking questions
    By fastturbovet in forum Moldmaking
    Last Post: 06-23-2005, 09:38 PM
  4. Controller program for MoldMaking?
    By NITRO in forum Moldmaking
    Last Post: 12-31-2003, 03:23 AM
  5. Curious about moldmaking
    By NeoMiller in forum Moldmaking
    Last Post: 12-25-2003, 01:01 AM
