I built a larger router [10 x 20ft] which has a slave driven X axis [20 ft]. Across the gantry is the Y direction =10ft.
The best way I've found to sqr my machine was as follows:
I know that when I do cuts in purely the X direction they will be straight and parrallel to only the X axis. So I put a pc of mat'l on the bed of my machine, placed it right tight against the -Y side of the bed.
Next I machined a reference edge on the pc so I know it was parrallel w/ the X direction.
Then I placed another pc of material which was sqr'd [placed against] w/ my reference edge.
I would machine one edge of the material purely in the Y direction. [Keep in mind that this pc was ~24" wide in the x and 8ft in the Y]. I would then cut a second pc of material exactly the same.
Lastly I would place the two pc's of material on the reference edge w/ the cut faces/edge towards each other [you'll need to flip one of your pc's- Rotate it only along the "Y" axis]. They can touch at one end [or use a spacer block of a known width] and will have a gap at the other end. By using a caliper I can measure the 'gap' accuratly. 1/2 the width of the gap is my 'out of sqr error' over 8 ft. W/ some quick math I was able to nail down how far I was out over the 10ft on my machine.
I am using prox switches for either end of the gantry [so Mach3 will auto sqr the gantry every time I home the machine] the sensing 'flag' is on an adjustable slide w/ a 20 pitch bolt. I can then move the 'flag' fairly accuratly to adjust for the out of sqr.
Repeat the test cut in only the Y direction again and I was off by a few thou.. Adjusted it again and it was perfectly sqr.. or as sqr as I could measure.
I haven't found a more accurate method than this.. and it took a bit of head scratching to figure out
Btw if this isn't too 'clear' let me know and I'll post some 'paint' pictures..
Fwiw
JerryFlyGuy
The more I know... the more I realize I don't
