586,675 active members*
2,857 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > yaskawa CACR HR10SB servo pack
Results 1 to 16 of 16
    Jan 2007
    18
    i am getting alarm 6 in both of the yaskawa CACR HR10SB sevopack drives for pallet changer & magazine rotation (machine is kitamura my centre H-400).Can any body help me?
    Nov 2006
    925
    You can download the manuals for the drives from the yaskawa site.
    Jan 2007
    18
    Hi gidley51,
    I have downloaded the manuals & also checked according to that but every thing seems to fine. But alarm still there i.e larm no 6 under voltage
    Nov 2006
    925
    According to the manual,error six is undervoltage as you say.Yaskawa`s explanation is to switch the power on and off and if the error is still there to replace the Servopack drive.It seems strange that both would fail at once without outside interference.Are you sure the input voltages are correct?
    Jan 2007
    18
    Hi gridley51,
    yes it seems strange to me also but it happened to me. Input voltage is o.k . today i am planning to dissemble the drives & check for some damaged parts may be thryster or some diode.If you have some more information for this alarm , Pl share with me.
    Jan 2004
    137
    Have you sent an E-mail to [email protected]? I found they are pretty good at answering E-mails.
    "Plan your work; Work your plan"
    Nov 2006
    925
    Sorry all I know is what`s written in the manual.I have never used Yaskawa drives although I have fourteen of them in the stores which I recently acquired along with matching motors.
    I too recommend you email Yaskawa.
    Mark.
    Sep 2008
    works for me...sort of.
    You can download SigmaWin+ software from Yaskawa, Thats what I did. I had the same thing happen= A.40 alarm in the software= overvoltage.
    I think mine is blown maybe yours too, some kind of power spike maybe. Anyway, the software connects to the drive and gives all kind of information,much more than I can understand right now but in a format that is understandable. AND, you can clear the alarm and reset it. You have to make a cable to connect, I made one out of an old RS232, the help file in the software shows the wiring diagram. Good luck.
    Jan 2007
    18
    hi j69usa,
    thanks for suggestion, but i have sent drive for repairs. once they come back, i will revert back to you . anyway thnx very much.
    Sep 2008
    6
    Hi there is chance fuse in the servo may be blown off.So pls check or there is also a chance of control card failure.If you require any upgrade support for yaskawa products in india you can contact me at Mob:+91-9967360681 Email:[email protected]
    Sep 2008
    6
    Aruuns
    Pls check the internal DC bus and there is chance of problem with contro card.If you require any technical assistance for yaskawa servo and Motion control products in inda You can contact me on Phone:+91-9967360681/Email:[email protected]
    Sep 2008
    6
    Yaskawa servo india
    Yaskawa servo technical support in india contact:ArunNS Hand Phone:+91-9967360681
    Oct 2008
    need help
    Who know about Servopack CACR-SV02ER?
    Sep 2008
    6
    Wink Yaskawa Servo INDIA
    Quote Originally Posted by wman View Post
    Contact: Arun N.S for Yaskawa Servo Support in India.
    Mobile:+91-9967360681/+91-9930044314
    Sep 2008
    6
    Smile Yaskawa Servo INDIA
    Yaskawa servo in India
    Call for Yaskawa servo Techinical support in India
    Arun N.S
    Mob:+91-9967360681
    [email protected]
    Sep 2008
    6
    Smile
    Arunns: Technical support for YASKAWA SERVO and MOTION controllers in India.
    Mobile:+91-9930044314
    Email: [email protected]
  1. Yaskawa Eprom IC for servo drive CACR-IR 1OSB
    By nice-day in forum Servo Motors / Drives
    Last Post: 02-12-2015, 03:17 PM
  2. Initializing servo amplifier Yaskawa CACR-IR30
    By ing.vic in forum Servo Motors / Drives
    Last Post: 09-02-2012, 10:31 PM
  3. YASKAWA ERROR 393 SERVO PACK (Z)
    By Northeastguy in forum Servo Motors / Drives
    Last Post: 06-08-2012, 05:11 PM
  4. yaskawa servo pack question
    By jeep534 in forum Servo Motors / Drives
    Last Post: 01-22-2006, 01:22 AM
