586,117 active members*
3,327 visitors online*
    Nono Guest
    cnc4pc c11g gecko
    on the c11g board I get all the lights for x and y but only 1 light for z..
    I checked the voltage for the board and I get a clean 5v.
    All of the e stop and limits are lit. when I power up the drives My geckos come alive and I get good motor lockup.
    In mach3 it shows in jog mode that the steppers should be moving.
    Not sure what to do or check.
    Nono Guest
    I just changed out the power supply and still no change
    May 2007
    15
    First of all. Is you ouput led on the C11G lit? If not, try to set the charge pump jumper to disable.
    If the output led is lit, and MACH showing that the axis should be moving, and you have "holding torque" on the motors. Make sure that you have a wire between the "common" port on the Gecko and the common port on your C11G. I.E If you have setup mach to ouput X-movement on pin 11, you will a connector next to it that is marked "+5v" (If I remember it right). You connect the common port on the Gecko to that one and make sure that the jumper saying +5V or common is set to common.
    Hope this helps. If I undestood you right I had the exact same problem when I first wired my setup.
  1. WTF C11G Gecko 203V
    By georgeburns in forum DIY CNC Router Table Machines
    Last Post: 11-02-2012, 03:34 AM
  2. C11G, Gecko 203v and Mach 3...connect what where?
    By teamtexas in forum Gecko Drives
    Last Post: 12-04-2009, 04:53 AM
  3. Relé interfase C11G
    By fenixes in forum Spanish
    Last Post: 05-16-2008, 06:29 AM
  4. C11G BOB and KBIC controller
    By xkbal in forum CNC Machine Related Electronics
    Last Post: 10-23-2007, 02:49 PM
  5. Gecko Cnc4pc Wiring Diagram
    By mlaws1172 in forum Waterjet General Topics
    Last Post: 09-15-2005, 12:14 AM
