586,076 active members*
3,693 visitors online*
Results 1 to 7 of 7
    Jan 2007
    129
    Fluctuating feed rates?
    Hey gang,
    I've been making chips with my V2XT and have been increasing the feed rates as I go along. I've found that when executing X Z arcs above 30ipm the feed rates cycle up and down from 30ipm down and back rapidly. I've done lineal G01 moves at 100ipm and up (with no problems) but the X/Z arc moves seem to accelerate / decelerate (though I've not tried it on X/Y arcs yet)
    I've searched through the machine settings through the PFM back end and through the BOSS front end and have come up with no solution.
    There is no feed rate changes posted via my post processor, so that's not the problem. Is there an acceleration setting I'm missing?
    Thanks all.
    Owen
    9 1/2
    B.C.I.T. Machinist CNC
    Nov 2004
    3028
    I remember that these machines could accel/decel feedrates when going around arcs inside/outside to keep chip loads/SFM the same.
    I believe there is a way to turn it on and off by code in the program.
    George
    Jan 2007
    129
    Yeah I was thinking the same sort of idea though, at this moment, I'm at a loss as to the M/G code. I'll have to look at the manual.
    Thanks.
    Owen
    9 1/2
    Nov 2004
    3028
    G44 cutter comp normal feedrate
    G45 cutter comp modify feedrate
    G99deceleration over ride
    Per the book, constant surface feed is imposed by G45 to reduce the feed around a inside radius and increase the feed around an outside radius as a function of the cutter diameter compensation in effect. cancel with a G44.
    Deceleration at the end of a motion block may be overridden by a G99 in the program line.
    Yes, read the book.
    George
    Jan 2007
    129
    Thanks George. I was already on that. I'll let you know if this changes my situation.
    As a side note, I noticed the post processor plotted my X/Z arc in short X - Z motions. Not X-Z I/K.
    Owen
    9 1/2
    Nov 2004
    3028
    I remember in G17 using X Y and R or X Y and I J.
    George
    Jan 2007
    129
    Well gave G44 and G99 a try but no luck ........... if any one else has and suggestions Please pass them along ....
    peace
    9 1/2
  1. Feed rates?
    By Rainman229 in forum G-Code Programing
    Last Post: 02-23-2007, 06:47 PM
  2. Feed Rates
    By rcheli in forum Benchtop Machines
    Last Post: 12-28-2005, 05:34 PM
  3. Rpm and Feed Rates
    By Xeno in forum Uncategorised CAM Discussion
    Last Post: 02-23-2004, 11:06 PM
  4. Feed rates in wood?
    By nervis1 in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2004, 03:57 PM
