586,988 active members*
3,751 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Tailstock Alignment Question
    Dec 2007
    Ive got a 1930's Atlas 10 inch lathe. I have two tailstocks for it; the original and an indexing one. They both read
    .008" above the center of the spindle. I would guess that the spindle has worn that .008 away over the last 70 years of use. The spindle is shimmed properly now so the question is do I get new bearings? Id rather not grind the tailstock base down, or should I? Thanks.
    Apr 2005
    460
    lathe tailstock
    Is it babit bearing ? and is the spindel worn If so deal with that first I think homeshop machinest had a series on a lathe rebuld . The tailstock could be lowered by taking the two halves apart and grinding the flat where it slides to set taper or shim the head stock up off of the bed . search HSM's website for the story and look at it . Good luck Kevin
  1. Haas SL-30 Tailstock question
    By chrisryn in forum Haas Mills
    Last Post: 05-07-2008, 07:44 PM
  2. tailstock (mis)alignment
    By ajbarrell in forum Shopmaster/Shoptask
    Last Post: 01-07-2007, 05:18 AM
  3. Mini-Lathe Tailstock Chuck Alignment
    By bowentw in forum Mini Lathe
    Last Post: 12-06-2006, 09:24 PM
  4. TL-2 tailstock
    By rbest27 in forum Haas Mills
    Last Post: 11-11-2006, 12:20 AM
  5. Q: Mini lathe Tailstock Alignment?
    By Deviant in forum Mini Lathe
    Last Post: 08-20-2006, 01:25 AM
