Hi All,
I've got a 8025mg that refuses to comunicate through DNC. Last week we came in on monday morning to find that the control refused to turn on. I sent the control to Fagor for evaluation, they found a dead CPU. They replaced the CPU, and we got it back and reinstalled it.
The arrangement is exactly the same as before the control left for service, we use WinDNC 4.1 on an older laptop with a serial port. No cables have been changed, I tested the cables for continuity between ends, and all check out.
Fagor used the RS232 port to reload the parameter tables before they sent it back to me.
Parameters all seem right 9600 baud, 8 bit, no parity, 1 stop. P607 parameter seems to have all the right settings.
With DNC turned on, (dnc indicated at the top of the control screen) I try to send a program from the control to the PC and nothing happens. If I try to send a program from the PC to the control, DNC flashes at the top of the screen, but a short bit later the PC indicates transmission error.
I've owned this machine for about 10 years, the current arrangement with the laptop and cables has been the same for at least the last 5 years.
It has been flawless up to this point. I'm baffled by this, and am greatful for any help.
