586,060 active members*
4,157 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > CNMG 432 DOC Limitations
    Nov 2006
    46
    Hello,
    Excluding workpiece rigidity and machine limitations.
    What is the max DOC I can take with a CNMG 432 insert on OD cutting ?
    As of right now, machining 4140 at 500 SFM at .100 DOC ( .200 on Dia. ) at .015 per rev. with coolant at about 60% spindle load.
    What do you guys think ?
    Regards.
    Tom
    Oct 2003
    263
    Based on what I've seen, .125 per side should be okay, much over that will likely start popping inserts now and then.
    You can do more with single-sided CNMM's, but only get two cutting edges.
    Software For Metalworking
    http://closetolerancesoftware.com
  1. Recommendations/Limitations
    By netmage in forum Benchtop Machines
    Last Post: 02-18-2008, 12:44 AM
  2. 4-axis limitations?
    By OC_ in forum FeatureCAM CAD/CAM
    Last Post: 05-17-2007, 02:43 PM
  3. THK SR type limitations
    By NC_jimbo in forum Linear and Rotary Motion
    Last Post: 04-19-2007, 02:25 PM
  4. Demo limitations ?
    By Redline in forum Mach Mill
    Last Post: 07-26-2006, 06:50 PM
  5. DC motor limitations
    By rippersoft in forum RC Robotics and Autonomous Robots
    Last Post: 09-08-2005, 02:58 AM
