I was wondering if anyone could recommend some good sources for getting some training with the programming ( other than taking a class)? I am completely unable to get to any classes due to the hours we are working at the office.
you can start with reading the user manual for the machine you want to run
the manual will explain how to use the 'G' codes
dont have any manuals. i dont run any type of cnc nor am i around any now. I am needing to get some basic experience somehow so i can pad my resume to set myself up for a different job...probably the wrong motiviation, but that is mine.
maybe i will search for G code on google and try to find a free manual.
are you looking to be a cnc part programmer or cnc operator
here's a place to start http://www.cncezpro.com/gcodes.cfm
There are many "benchtop" CNC machines, even engravers, that would be a good learning tool and possibly affordable if you are serious. The knowledge is the same whether the machine is large or small. Even a two-axis table using a felt-tip marker instead of a spindle would help you. Also, just some Cad/Cam software with simulator capabilities without a machine would be helpful. Mind you that if you add it to your resume' and someone takes it literally they assume you have some machining knowledge as far as processes and speeds/feeds/tooling.
