These came on my CNC mill, which was DIY'ed by someone else, and I need a few more of these connectors. Any of you recognize it? It is keyed, with 5 pins. Best pics I have for now....
-Neil.
-Neil.
It appears to be an industrial strength DIN connector, they come in a few pin patterns, but are predominantly 5 pin.
There should be a number or manuf mark somewhere on the connector, It looks like a twist-lock type.
Al.
Albert E.
Yep -- twist-lock. Plug straight in, then twist the "serrated" outer ring to lock it in place. I don't remember seeing any marks, but I'll go back to the machine and check all three to see if I can find something.
-Neil.
What about: http://www.switchcraft.com/products/connectors-28.html
Chris Kirchen
