hello everyone. i came across this site while doing some research on my own. ive gotten into several hobbies through the years, and i must say, this one has a TON of scattered information. every day i find something new and confusing. ive collected a lot, and know a lot more than i did, but little of it fits all together.
here is what i already "know". i generally know what a CNC machine is (the original goal was to make a CNC-type machine), that led me to the research. i know that its an computer-based interpretation/control system that reads input (from a file or from a user) and manipulates a machine. im good with that.
next, i am familiar with stepper motors, servo motors, and movement. i know i will be using stepper motors (for cost and for simplicity). i know generally what size to get (the biggest i can get surplus ) i know the more steps, the better, etc...
then i get confused. i am somewhat unsure of how a "milling machine" is different than lets say a drill press. i understand the differences in chucks and lateral forces. but, im still trying to grasp what makes a milling machine a milling machine, and not just a beefy drill press. BUT, for my purposes, this is irrelevant.
next, i get that steppers need controllers. that's a given. and i understand you can control a stepper with PC software. what i DONT understand is how you link stepper software, controllers, motors, etc... i dont get how it all works together. this also leads into my confusion about software. ill get to that next.
i found a few stepper motor controllers on www.kitsrus.com (kits 179, and 113 i think). 179 says it can control a motor through a PC, or direct, and you can hook up to 6 motors to a single PC. how?
i see MANY controllers online and most look almost identical, but prices vary a lot. i see many in the $50-$100 price range, and then some in the multiple $100's range. why is this? what is the main difference?
phew, so good so far. next, how does the software communicate exactly? i dont care about the technical details, but if i want to make two holes, 3 inches apart, how do i say, "move three inches right". it is all in the form of steps (which i understand), but do you have to just know how many steps is equal to an inch, or is there some interpretation?
lastly, ive seen a whole lot of software that appears like it can do CAM functions. however, what feedback is there to tell the machine where the bit is at a given time, and where it NEEDS to be? is there a way to zero the machine without feedback from the computer? it seems like you can move the bit, map the bit's movements, but the computer seemingly has no idea where the bit actually is. do you always start from a zero point, or do you just have to "zero" the workpiece?
ok, so there are my questions. as soon as im done, im posting all the stuff in a NICE Q&A on my website (which is a pretty good amount of visitors in the DIY audio realm.). this will help a few people. im pretty good with this stuff, but the information thats out there is really hard to grasp.
so, here is what i'm after for now: well, answers of course, but here is what i am trying to build/accomplish:
i currently have a 12" drill press thats 2/3HP i think (its a craftsman). i understand that they dont make great milling machines becuase they dont like a whole lot of lateral force. this is fine. ill explain later. i just recently bought a milling table off ebay. its got 11" x 7.5" travel. its decently built (~70 pounds). it has some play in it, but i can fix that.
what i "need" to do is make a machine that drills precisely. not terribly so, but i just want stuff to be lined up right. also, it would be NICE if possible to be able to cut rectangular sockets (for AC inlets, computer ports, etc...) out of thin aluminum (maybe 1/16" or 1/8" thick). the limited lateral force on a drill press should handle that.
so, i have the table, the drill, and access to surplus stores. i recently saw some steppers at a local surplus shop that appeared bigger than most of what was used for the smaller mills for around $15 each. they were 5 wire motors i think. they were pretty good sized.
i also have an extra computer thats not in use. its a 2.2ghz with all the fixings. this will get devoted to the CNC mill. one last question, ive seen parallel PCI computer cards... can i use maybe 2 paralell ports for further control? not necessarily more axes, but for maybe reading measurements (DRO fed into computer?).
well, i REALLY appreciate everyone's help. on a last note... i dont expect insanely high tolerances, precision multi-angle milling, etc... i know i cant accomplish that with what i have listed. the ULTIMATE goal is to learn what im doing, and to make a full gantry setup that would allow me 2' travel in both drirections, and full milling cababilities, so i can do more complex metal work. but for NOW, i just need a drill press thats computer controlled, so i can layout hole patterns that looks CNC'ed.
