586,103 active members*
3,404 visitors online*
    Jan 2008
    19
    writing G code
    Hi all, I've been running a few test programs on Mach3 using the supplied wizards but want to write some simple G code programs myself.
    This may sound like a really dumb question but,
    Do you need software to do so or can you just sit down and type the code in like in a word document and then save it?
    Have tried that but when I try to load it into Mach3 it dissapears.
    Any ideas/suggestions??
    Cheers very much,
    Steve.
    24221
    Anything like WordPad should work, make sure it saves as ASCII text, no embedded codes.
    Also you can write and run it in a free simulator like
    http://www.cncsimulator.com/
    Al.
    Albert E.
    Jan 2008
    19
    Thanks Al, much appreciated,
    Steve
  1. FANUC-OMC / PMC ROM WRITING
    By iNUC in forum Fanuc
    Last Post: 06-07-2013, 05:45 PM
  2. Writing DRO to from G31 to files
    By Harrison Wedge in forum G-Code Programing
    Last Post: 08-31-2008, 10:35 PM
  3. imagine writing the code for this!!!!
    By bearracecars in forum Waterjet General Topics
    Last Post: 02-19-2007, 10:46 PM
  4. Writing words
    By JDARSNEK in forum G-Code Programing
    Last Post: 11-27-2006, 09:42 PM
