586,639 active members*
2,846 visitors online*
    Sep 2008
    hitachi 20 sii with yasnac lx3 control
    we have aquired a hitachi machine(20sII) which has been running in metric, when we ran a prog with G20 (to change to imperial) the T00 workshift figure in the offset page did not convert in the X axis, it just divided the 250mm it was in metric to 25 inches and the machine overtravels in X, is there a parameter or setting you have to change when moving from mm to inches. The T00 figure in x will not let you update it manually (it should be 9.8425")--any help would be appreciated
    Jan 2007
    333
    LX3/MX3 PC System Instruction Manual
    http://www.yaskawa.com/site/dmcontrol.nsf/(DocID)/MNEN-5CLKGH/$File/LX3-MX3%20Instruction.pdf
    LX3 Instruction Manual
    http://www.yaskawa.com/site/dmcontrol.nsf/(DocID)/TKUR-5EKJ89/$File/TOE-C843-9.20D.pdf
    LX3 Operator's Manual
    http://www.yaskawa.com/site/dmcontrol.nsf/(DocID)/TKUR-5EKJA3/$File/TOE-C843-9.21E.pdf
  1. %$@*^!! Yasnac on a Hitachi
    By Paul in OK in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-07-2008, 03:51 PM
  2. Hitachi Seiki with Yasnac LX1
    By besc in forum MetalWork Discussion
    Last Post: 12-21-2007, 03:35 AM
  3. Homing problem with a Hitachi HT-20 Lathe, Yasnac
    By Stoney372 in forum DNC Problems and Solutions
    Last Post: 10-02-2007, 01:39 PM
  4. Hitachi Seiki with Yasnac LX-3 Error
    By dannyboysd89 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-08-2006, 01:54 PM
  5. Yasnac i80m no DC control circuit power
    By randyh in forum DNC Problems and Solutions
    Last Post: 09-09-2005, 09:21 PM
