586,096 active members*
3,208 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > CNC Portraits From Photos?
Results 1 to 3 of 3
    Sep 2008
    Hi, I use a 3 axis CNC machine at work and was wondering how easy it is to produce CNC portraits like the ones here?
    http://www.untothislast.co.uk/Access...Portraits.html
    We currently use both AXYZ Toolpath and RhinoCAM software. Do you need special software to create these portraits?
    Any help would be greatly received.
    John
    35538
    CNC Portraits From Photos with SuperCamXp
    There is a demo version of SuperCamXp at:
    http://www.super-tech.com/root/grp.a...uperCamXp-Demo
    With it you can generate G&M code files for line width engraving and point per pixel engraving. It works with BMP black and white files.
    Here is a web site with an effort to explain how to directly run it on a Taig Mill.
    http://www.super-tech.com/root/grp.a...CamXp-HowToBMP
    You will note at the bottom right corner there is a button with GenGcode as the legend. It will create a G&M code file of the current settings. You don’t get a chance to name the file, the file name created is displayed in the console area at the bottom left, yellow background.
    I have yet actually run one from the code file generated.
    Dennis
    www.super-tech.com
    Attached Thumbnails Attached Thumbnails SCXP_RosePicture.jpg   SCXP_RosePicture_Clipped.jpg   SCXP_RosePicture_Clipped3D.jpg
  1. Need help engraving photos
    By terry32506 in forum Engraving Machines
    Last Post: 03-31-2010, 10:48 AM
  2. help with photos
    By Mike Boarman in forum Mach Software (ArtSoft software)
    Last Post: 12-21-2006, 09:06 PM
  3. I need tip on engraving photos
    By harolda in forum Community Club House
    Last Post: 03-31-2005, 04:47 PM
