586,117 active members*
3,438 visitors online*
IndustryArena Forum > CAM Software > Vectric > chipload calculator
Results 1 to 8 of 8
    Nov 2007
    2466
    chipload calculator
    here it is
    jim
    Attached Files Attached Files
    Aug 2010
    Hi Jim,
    Thanks for this. What units are the feed rate in?
    Cheers, Ben
    Nov 2007
    2466
    i used it this week and it is in inches
    James McGrew CAMaster 508 ATC
    www.mcgrewwoodwork.com http://dropc.am/p/EJaKyl
    Nov 2007
    2466
    here is another calculator near the bottom of the page just download "cnc toolkit" and go to tools
    Josh Glenn’s Blog » DIY-CNC Tutorials
    Aug 2010
    Hi Guys,
    Thanks very much for all the info. Its great. Would any of you know of a speed / feed calculator that is metric?
    Cheers, Ben
    May 2009
    435
    I entered some numbers in the XLS file
    Enter desired chipload: .035 (for natural wood)
    Enter RPM: 10000
    Enter # of flutes: 2
    Feed rate = 500
    Is the 500 "inches per minute"? I don't even think my DIY can do 500 ipm rapids, much less cut at that speed. And that's on the low end, my Porter Cable 690 variable speed does 10,000-27,000 rpm.
    .035 is a very high chipload, much too high for solid wood. So yes, 500 would be ipm.
    However, with most 1/4" tools, cutting hardwoods, a chip load of .003-.007 would be more common.
    Chiploads over .015 are probably more than most handheld routers are capable of, or are nearing the limit.
    May 2009
    435
    Thanks, I was looking at the recomended chip loads for hard and soft wood on the Onsrud site for Ø1/4" bits. The maximum chip load is .017 on some bits, but most of them are .009 or under.
    Onsrud chip load charts
    Some other useful tips on there:
    To increase your chipload you can:
    Increase the feedrate
    Decrease the RPM
    Use less flutes
    To decrease your chipload you can:
    Decrease the feedrate
    Increase the RPM
    Use more flute
  1. What size chipload and depth of cut based on diameter of endmill?
    By wwendorf in forum MetalWork Discussion
    Last Post: 01-02-2008, 08:21 PM
  2. Looking for a threading calculator
    By northernmach in forum MetalWork Discussion
    Last Post: 12-09-2006, 02:01 AM
  3. CNC Axis Calculator
    By MrBean in forum Coding
    Last Post: 09-17-2006, 12:19 PM
  4. steps Calculator
    By slp_prlzys in forum DIY CNC Router Table Machines
    Last Post: 04-10-2006, 07:24 PM
  5. calculator in Autocad
    By rfstar in forum Autodesk
    Last Post: 04-12-2005, 07:38 PM
