586,670 active members*
3,443 visitors online*
Page 11 of 11 91011
Results 201 to 219 of 219
  1. #201
    35538
    Now, I don't have a way to do the flat-bottom bore in aluminum
    If you have a router, then sure you do. Make a template out of your plexiglass, and drill your aluminum just a little bit undersize. Then, use a short pattern bit and route out the remainder of the hole. Here's a link to some pattern bits. http://www.eagleamerica.com/product....pn_E_102-0552B
    If you find that the holes too tight for the bearing, make the template from MDF. It will give a little, and give you a slightly bigger hole.
  2. #202
    Jun 2004
    487
    Very nice thread with lots of pics; keep them coming. Dude, it might not come out perfect but if I can help you cutting out any part you need while doing the build, by all means. In a pinch, I use a compound vise on the drillpress to do rough milling. It helps while the mill is down for repairs.
    JR
  3. #203
    Mar 2004
    847
    Quote Originally Posted by ger21
    Yeah, I guess that is true. (chair) Let me admit something embarrassing here though, I haven't ever used a router by hand (well, a tiny bit with wood). Yeah, I know, probably not the best idea that my first real router use is going to be with it bolted to servos on a CNC platform. I'm actually thinking of taking the router class at the local Rockler's. Anyone ever taken any of their classes? Worth it?
    Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
  4. #204
    Mar 2004
    847
    Ok, got a ton more done this week but I have been slow to go through the photos and post an update - so here is a quick one with more to come later.
    Drilling the plate that will be the bottom of the gantry. This mounts the the slides on the rails:
    Now, I ordered a 21" piece of bar-stock (2" x 3/4") which I need to cut down to two equal pieces ~10" in length. These will form the gantry uprights...
    Marked and ready for cutting:
    Cut, now I will take a very thin cut off of the ends while they are clamped together. This should give me a pretty square and even surface for both parts.
    Cut done, and a perfect finish. I love this saw...
    Now to square-up the gantry sides:
    Again, super smooth - did I mention I love this saw?
    I decided to take a notch out of the gantry sides (what will be the 'front' and top of the plates when mounted) for purely cosmetic reasons.
    Now to square-up the two plates that make the bottom of the gantry:
    Yes, two bottom plates. I modified my design to give it some added rigidity - there should be almost no flex side-to-side in the gantry...
  5. #205
    Mar 2004
    847
    Ok, now that I have all the metal cut and squared for the gantry it's time to get it drilled and put together.
    First to drill is the rear-support bars:
    Next, I had to drill holes (that will be tapped) in the gantry sides to mount the support bars. A little bit of a PITA since they need to be drilled on edge, but I managed to get my drill-press set-up to be pretty repeatable without much adjustment.
    Little closer showing the actual holes:
    Coming along good, gantry sides with the support-bars bolted on:
    Now I need to drill the holes in the gantry sides to mount them to the lower gantry cross-members:
    ...and here is what the gantry looks like (minus the Y-Axis assm. and Z-Axis):
    (You can see I got excited and mocked it up before drilling the rest of the holes in the sides...)
    Just have to get the Y-Axis assembly mounted up, then I can start on the fun task of making the Z-Axis!
  6. #206
    Feb 2005
    521
    Arr hole drilling...yup...remember that part. Can't see much swarf about, you must be pretty tidy!
    This is really coming together Javadog. I'm enjoying this thread immensely. This should be a beast when done; great for aluminium and maybe even steel. Just don't drop it on yer foot. Looks bloody heavy!!
    Always impressed with your photos...Aluminium is a bugger to photo.
    I love the schedule in the background...
    "Buy Wire, Assm. Control Box, Test Electrical, Put Hair Out, etc..."
    Nearly there!! :banana: Best part is, seeing what you've made without CNC and thinking what your going to get up to with that monster at your disposal. Promises to be entertaining!!!
  7. #207
    Mar 2004
    847
    Just want to let you all know, my ISP is having a problem with the personal storage space I use for hosting pictures. My FTP access has been down for the last week+, but it is supposed to be fixed soon. As soon as it is, MASSIVE update time.
    No need to offer alternate storage space, I bought a domain and I am going to get a good hosting package soon. I don't think my ISP's "free storage" is going to cut it much longer, especially since I am 160mb over their 10mb "limit"!
  8. #208
    Feb 2004
    813
    I don't visit the Dark Side of the forums (wood routers)
    But i must say JavaDog
    "nice build"
    keep up the good work
  9. #209
    Mar 2004
    847
    Quote Originally Posted by Stevie
    "nice build"
    Thanks, and you're right - this should be in the metal routers section (which didn't exist when I started the build!).
    Time for an update!
    Marking where the upper gantry-plate meets the gantry sides. You can see that I have drilled and tapped the holes into the lower gantry-plate:
    Mounting holes drilled for the upper gantry-plate:
    Now to drill and tap the holes in the upper gantry-plate:
    Drilling holes on the ends of these long plates was a PITA with my little drill-press. I needed to undo the base and reverse it so that I had the clearence.
    Gantry plates mounted up (not all the bolts are installed in this picture) and the Y-Axis plate clamped up to make where to drill:
    Y-Axis plate drilled, tapped, and mounted to the gantry supports (I need to get shorter bolts):
    Y-Axis ballscrew/slide assembly clamped up to the plate:
    MDF top (not cut to size yet) to get a good idea of what she is going to look like. There is 5.5" of clearence between the bottom of the Y-Axis plate and the MDF top:
  10. #210
    Jul 2005
    3
    I thought I would de-lurk for a bit and congratulate you on your progress.
    Looks like you are getting awfully close...
    I followed you here from the Bit-tech forums almost a year ago, and I guess I have you to thank for getting me started on this hobby. I have been working on my own table, and I am reminded that I need to post my own build log.
    Also, looks like you were mentioned on hackaday.com, congrats. :cheers:
  11. #211
    Mar 2004
    847
    Ok, bolted the Y-Axis Ballscrew to the Crossplate.
    Now to make the Z-Axis!
    Here is how the Ballscrew and Linear Slide will be laid out (more or less) for the Z-Axis:
    Have to drill the holes to mount the Z-Axis plate to the Y-Axis Slides:
    ...and counter-sink them:
    Here is what it looks like bolted to the Y-Axis:
    You can see that I need to make a bearing-block for the end of the ballscrew, and finish up the Z-Axis...
  12. #212
    Mar 2004
    847
    Making the Z-Axis Ballscrew bearing-plate. For ease, I decided to make it out of polycarbonate. I will make a new one out of aluminium down the road...
    Forstner Bit, Poly-carb and the top OEM bearing-block:
    Drilled with the bearing mounted:
    Mounting holes drilled and tapped:
    Re-Tapping the end of the ballscrew:
    All done and mounted:
    Now to mount the linear slide...
  13. #213
    Mar 2004
    847
    Dual row of holes drilled for the linear slide:
    Tapped:
    Mounted:
    Now I wanted to add some physical stops so I didn't lose the slides off the end of the rails (big PITA):
    That will do it, not going anywhere now.
    Ok, now I needed to add a 1" thick block to get the mounting height for the ballscrew and linear-slide even:
    Marking the holes:
    Drilled and mounted:
    Then I drilled and tapped four mounting holes for the plated that will hold the router to the Z-Axis assembly:
    On to the Servo mounting!!
  14. #214
    Mar 2004
    847
    Laying out the cut-lines for the Servo mounting plates:
    All cut:
    Now, where they mount to the machine itself, I wanted it adjustable - that way I can get the belts on and tensioned correctly.
    First, drill a bunch of holes:
    Then, file like the Dickens:
    Now to drill the holes to mount the servos to the plate:
    Then using two different step-drills I enlarge the center-hole to fit the little lip on the servos. That way they will sit flush against the plates:
    Perfect:
    This is the Z-Axis Servo Mount, but you can see how the Servos fits like a glove:
  15. #215
    Mar 2004
    847
    Of course, I need to mount the Servo to the front plate for the X-Axis!
    Here you can see where the spindle for the X-Axis ballscrew come through the front frame-plate:
    The Servo-Mount all finished:
    Then I had to enlarge the hole for the X-Axis ballscrew to fit the hub of the Pulley. Since I have a small drill-press that couldn't reach, I used my cordless drill (worked like a champ):
    Back to the Y-Axis plate and the Servo Mount. I needed to notch the spot where the plate mounts to the Y-Axis cross-plate:
    Perfect!
    Except for...
  16. #216
    Mar 2004
    847
    This big glaring mistake...er rather, just something I didn't think of:
    With the servo mounted this way for the Y-Axis, the Z-Axis servo would hit it when it still had almost five inches of travel left:
    So, to re-work the mount and swing the Servo to the other side. I decided I would just use a second plate and make some stand-offs.
    Cutting the stand-offs:
    So, it would make the mount work like so:
    Of course, I broke my nice 4mm tap:
    Now I will leave you with a teaser of the finished machine:
  17. #217
    Mar 2004
    847
    So, the Y-Axis Servo Mount had to be re-designed. Turned out I made the standoffs too tall and there was too much side-to-side mis-alignment between the pulleys.
    So, just turned the standoffs on their side. Took the spacing from 1.5" to 3/4" - which turned out to be perfect!
    Pretty easy fix. Next I am going to post pictures of the electronics and control box - all finished. Then, final pictures of the machine (high-res) and VIDEOS!
  18. #218
    Jul 2006
    102
    Maybe I'm missing something here, but Javadog's last post was just over a month ago so I'm wondering if this project finished?
    Did Javadog ever post any finished work or videos?
    Maybe he is just on vacation..
  19. #219
    Dec 2003
    128
    Quote Originally Posted by Miata2k View Post
    Was this machine ever finished. I read the whole thread to find out that it is a mystery whether this machine was finished....
Page 11 of 11 91011
  1. Student Building a CNC Machine for Metal
    By MetalCNCing in forum Knee Vertical Mills
    Last Post: 12-19-2005, 01:28 PM
  2. Heads Up - Article about building CNC Milling Machine
    By samualt in forum Community Club House
    Last Post: 06-13-2005, 08:43 PM
  3. Help needed in building a CNC machine
    By aran.nav in forum Stepper Motors / Drives
    Last Post: 01-12-2005, 01:40 AM
  4. When you done building your CNC machine
    By Todd Price in forum DIY CNC Router Table Machines
    Last Post: 04-22-2004, 05:14 AM
  5. best tooling purchases made for building your CNC machine
    By pminmo in forum DIY CNC Router Table Machines
    Last Post: 04-10-2004, 03:28 AM
