student1616
While you are lazy with your shift key, that same attention to detail with earthing and shields also applies. now i've had that gripe...
Think of the CURRENT that passes through conductors. If a current can flow because something is terminated then voltage can be induced in that conductor.
Output wires will induce current to flow in other conductors.
The purpose of a shield is exactly that it is a shield.
If it is terminated at both ends, then current can be induced in it and it's shielded wiring.
There is not enough space here, but simply put -- GET RID OF INDUCED CURRENTS.
Learn proper wiring practices and understand why it is done a particular way.
Circuit board layouts suffer the same problems. Any loop can have current induced in it.
I have had to mix audio cables with cables running 800A pulsed and it can be done without any filters. UNDERSTAND INDUCTION. PROBLEM SOLVED.
