586,068 active members*
3,706 visitors online*
    Feb 2006
    12
    Pallet Change Speed
    Is there a parameter that can be edited for the sec/rev. time on a horizontal cnc w/ pallet change.
    I have a '94 model Saeilo Mach 3 Horizontal CNC with a Fanuc OM control and a turntable style pallet change. I am about 50 lbs. shy of the maximum weight limit for the tables. My problem is when I program a pallet change that there is so much momentum with the rotation that the whole turntable slams into the rubber bumpers. The book says it should be currently 10 sec/rev. I am setting the machine up for production and I don't think it would be a good thing to keep running the machine as is. I guess worst case, I set up a new fixture but with less parts to hold. I am currently holding 4 parts. 2 per tombstone. I've looked thru the books and did not find any such parameter to change this. Anybody out there have any ideas?
    2932
    Are you sure the rotation is not hydraulic or pneumatic? If so, there should be flow-control valves and cushions to control this.
    Feb 2006
    12
    I believe it's hydraulic. The hunt begins!!!
    Thank you.
    Jan 2006
    59
    I agree with dcouper. as far as the "hunt", the cylinder cushions should be on the end caps of the cylinder. Usually a set screw with a jam nut. Its does not take much adjustment on these so make small adjustments to them.
    RRL
    Jan 2007
    18
    you can adjust the cushioning of hyd. cylinders
  1. Pallet Change
    By CNC Mendez in forum G-Code Programing
    Last Post: 01-25-2017, 02:48 PM
  2. HAAS HS-1 Pallet Change problems
    By cweiss in forum Haas Mills
    Last Post: 07-30-2008, 10:42 AM
  3. pallet change program, needed
    By stew in forum Fanuc
    Last Post: 01-02-2008, 08:45 PM
  4. How in the world do you change the jog speed?
    By cncadmin in forum Mach Mill
    Last Post: 01-07-2007, 06:42 AM
  5. Does controller change axis motor speed?
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 10-10-2003, 10:05 PM
