586,096 active members*
3,727 visitors online*
    Jul 2008
    7
    Question Program restart issues HTC400 M-Plus
    I am going brain dead.
    I have a HTC 400 with the M-Plus
    Programs using EIA
    How do I restart in the middle of a program - I call the program out to view in the "window" but I cannot get the cursor into the view.
    Dec 2007
    300
    I don't remember the exact procedure but you need to have a "N" number at the point you want to restart from. Put a N block at each tool change line so N1T01 is tool 1 N2T02 is tool 2 etc. When you get to the part were you enter sequence number for restart that would be the tool you want to restart from. You need to press the "sequence number search" "Input" and it should find the proper N number to start on. Then "Cycle Start". Again, I am going from memory and don't have a machine handy to try it out so I may be a little off but that's roughly what you need to do. I have an M+ at my shop and will get it exact if you need it later.
    Mar 2005
    988
    For M+....
    Be in "MEMORY" mode. Go to the EIA MONITOR screen. Cursor down to where you want to start. Select the "RESTART NON MODAL" button on the screen. The line should highlight. Press "CYCLE START" button.... You don't 'need' a line number (N). You can start anywhere. Just be sure you start from a line that will read the info you need though (Work offset, B axis, coolant, spindle on, speed, G43, etc, etc).
    If you want to skip start somewhere in mid cut or tool operation for EIA... that's another story...
    It's just a part..... cutter still goes round and round....
    Dec 2007
    300
    My memory did fail me. The method I described is used on the M2 control with no EIA monitor screen.
  1. Restart with sub programs
    By Phil S in forum Okuma
    Last Post: 03-19-2008, 11:33 AM
  2. Program Restart in mid program?
    By Donkey Hotey in forum Haas Lathes
    Last Post: 03-18-2008, 08:19 PM
  3. Mid program restart
    By HuFlungDung in forum Haas Mills
    Last Post: 06-26-2007, 10:32 PM
  4. Restart of integrex eia program with dual turrets
    By Bobc007 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-02-2007, 01:43 AM
  5. haas floppy dnc restart
    By bytecolor in forum Haas Mills
    Last Post: 10-19-2006, 01:31 PM
