586,103 active members*
3,819 visitors online*
Results 1 to 6 of 6
    Oct 2007
    7
    Mori Seiki Lathe Error 414
    We have a Mori Seiki SL-25B/1000 lathe with a Fanuc MF-T6 controller. Every so often there is an error, actually two at the same time, 401-x axis vrdy off and 414-x axis detect ERR. The darn thing may run for 2-3 hours then boom the errors. They have always happened while it is machining. Thought maybe someone may have had this problem also. Thanks in advance for any assistance.
    Sep 2008
    27
    check the door safety lock...
    Oct 2007
    7
    Quote Originally Posted by PTtec View Post
    Darn, I did not even think of that. Sounds like it could be that though. I will have to clean the thing and check it out to see if it happens again. Thanks
    Sep 2008
    33
    I HIGHLY doubt you'd get a 414 alarm from a door switch.
    Check diagnostics 200 and 204. Make a note of the bits that are on (1). Also, check the LED display on the X axis servo.
    DGN 200
    Bit 6 = Low voltage
    Bit 5 = Overcurrent
    Bit 4 = High Current
    Bit 3 = Over Voltage
    Bit 2 = Discharge Alarm
    Bit 1 = Disconnection Alarm
    Bit 0 = Overflow Alarm
    DGN 204
    Bit 6 = A/D Converter abnormal
    Bit 5 Magnetic Contactor faulty
    Are these alpha drives? If so, you'll probably need to send the drive out for repair. If they're not alpha drives, you might have a transistor module going bad. Transistor mods are a pain to check, but will cost a lot less to repair.
    Other things to check....
    X-Axis brake not releasing fully. It's basically an electro magnetic release. If the coil's going bad, it'll stop functioning when it gets really hot.
    Check that all of the cooling fans in the electrical cabinet are working. If they're not, you could try running with the EC door open with a fan blowing inside. I don't recommend doing this for long periods of time. Oil, grease, and coolant aren't good for electronic components.
    Oct 2007
    7
    Thanks Phix I will check it out.
    Jan 2007
    333
    Quote:"Also, check the LED display on the X axis servo."
    Let us know.
  1. Replies: 1
    Last Post: 01-25-2010, 08:13 PM
  2. Memory alarm on Mori seiki lathe
    By hectorbach in forum Mori Seiki lathes
    Last Post: 01-06-2010, 01:04 AM
  3. Mori Seiki SL-403 Lathe
    By alc1960 in forum Mori Seiki lathes
    Last Post: 09-23-2008, 03:35 PM
  4. CNC LATHE MORI SEIKI Diagnostic Parameter
    By suleman_mani in forum Fanuc
    Last Post: 05-19-2008, 08:47 AM
  5. nam sun lathe/mori seiki knock off
    By jheyliger in forum Uncategorised MetalWorking Machines
    Last Post: 04-27-2008, 07:42 PM
