I am using a laptop that I plug a second monitor into when I am at home.
At some point the "Selected Entity Info" window must have found it's way off the screen, it is not showing up on either monitor.
Any way to reset the position?
Can you disable second monitor thru laptop settings?
Andre',
The attached file contains registry settings that will reset the entity info window position. Close NCPlot, unzip and double-click the attached file and confirm that you want to add the settings. This file is for v2.05, if you have a different version let me know and I'll get you a reg file for it.
Thanks,
Scott
