586,111 active members*
3,097 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Doosan S 280 Fanuc 9000 parameter for M06, M07
Results 1 to 6 of 6
    Sep 2008
    I need the 9000 series parameter(s) to enable a parts catcher. I hooked up the sol. valves, reed switches, etc. and the diagnostics see the inputs going high as I manually cycle the air cylinder. The solid state relay and solenoid for parts catcher return is live but the machine won't respond to M06 or M07. Thanks, Donnie
    Nov 2007
    188
    PARTS CATCHER
    I may be wrong but I think you need M10 and M11 for your parts catcher
    Jul 2003
    263
    you need to let the machine know the parts catcher is attached to it
    keep relay K8.5 activates and deactivates the parts catcher check your manual or if you can understand the ladder logic go thru it and look for the parts catcher. the keep relay and parameter ( if needed) is listed there
    i do not think it is a parameter you have to change but it is more than likely it is the keep relay
    If you can ENVISION it I can make it
    Sep 2008
    Keep Relay and M Code
    I checked the book and the only reference to a keep relay (K4 bit 6) is "Parts catcher on axis interlock". The Doosan manual lists M6 and 7 for the parts catcher. Thanks so much for the quick replies guys...... Donnie
    @chucker
    you're right, part catcher M-codes are M10 and M11 unless user modified.
    standard doosan its M10 and M11
    Quote Originally Posted by resuengineering View Post
    @chucker
    No. The M-codes for the Mecatec/Doosan S280 Parts Catcher are M6 & M7
    Doosan S280 M-Codes.pdf As shown by this extract from the S280 Operators Manual
    I do not know how to turn on the Parts Catcher
    Which Fanuc control do you have on this machine ?
  1. FANUC 15M Parameters 9000 how to enter?
    By posedi in forum Fanuc
    Last Post: 09-26-2020, 01:24 PM
  2. doosan fanuc 18t turret
    By julio_gyn in forum Fanuc
    Last Post: 05-19-2008, 06:43 PM
  3. Back up 9000 range on Fanuc 0M-C
    By OC_ in forum Fanuc
    Last Post: 01-16-2008, 09:32 PM
  4. Replies: 2
    Last Post: 02-15-2007, 03:10 AM
  5. 9000 series parameter list
    By IcutPoly in forum Fanuc
    Last Post: 11-12-2006, 12:08 PM
