586,051 active members*
3,843 visitors online*
Thread: Setup sheets
    Apr 2004
    353
    Setup sheets
    What are you guys using to make/store/catalogue setup sheets.
    We use Gibbscam and Mastercam, and both setup sheet options in each software package don't seem very user friendly to me. I'm curious what others us to keep track of everything. We have a small shop, 10 machininsts, only two of us are programmers. Right now we have ton's of old paper files that we use with our setup sheets but they often get misplaced or wrecked. We're looking for an alternate method (maybe stored on computers) that will make is very user friendly for everyone to use.
    thanks for any input
    Post Cute PDF Writer
    I would use CutePDF and generate a PDF file from the CAM software your using. You can then access the set-up sheet from any computer.
    http://www.cutepdf.com/
    Independent CNC Programmer
    www.ctcn.net/~3kings/
    My mission is to share CNC programming innovations for a lifetime.
    Feb 2008
    586
    I have a small(one person) shop, too. I use OpenOffice to create my setup sheets, then save them as PDFs for printing when a job is ready to run. Scibblr all over the printout to modify the setup sheet for the next run (job notes, problems, solutions, measuring techniques, etc.
  1. Carbon Sheets
    By barkster in forum Hobby Discussion
    Last Post: 11-03-2008, 01:03 PM
  2. Cheat sheets....
    By KaesynCAM_Tech in forum Mori Seiki lathes
    Last Post: 09-30-2008, 03:47 PM
  3. Panel saw that will cut 4ft x 8ft sheets
    By Router Lady in forum Want To Buy...Need help!
    Last Post: 09-18-2008, 05:09 AM
  4. Cutting Aluminum Sheets
    By barkster in forum DIY CNC Router Table Machines
    Last Post: 03-01-2004, 05:12 PM
  5. set-up & operation sheets
    By Bill in forum Community Club House
    Last Post: 08-08-2003, 04:15 PM
