586,058 active members*
3,437 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Two OM-s, different behaviour [UPDATED]
Results 1 to 8 of 8
    Mar 2006
    107
    I have two machines both with Fanuc OM, only visual difference is that one has soft keys and another doesn't have.
    1.
    On one machine if I put R after G1, it will make radius between two G1-s (two lines).
    And second machine doesn't do that radius, just sharp corner between two lines.
    I can't remember other differences right now, but will post it later.
    Sorry for bad english
    Jan 2007
    333
    There is a parameter setting that allows a choice between using "R" or using "I, J (K)"
    Apr 2007
    27
    I just stumbled across a thread on this today. Check this out http://www.cnczone.com/forums/archiv...p/t-23343.html
    Maybe it will help.
    Mar 2006
    107
    Quote Originally Posted by bborb View Post
    At my older machine, for G2 and G3 I can use both R and I,J,K, and for G1 (linear) I can use R to make radius between two G1-s.
    Probably that should be some parameter....?
    Mar 2006
    107
    NEW PROBLEM:
    One machine does subtract tool length for abs/rel coordinates if G43 H_ is activated, and another does not.
    Could that be changed through some parameter?
    I like when coordinates are shown with tool length compensation.
    2nd PROBLEM:
    When in offset screen (tool length register), one machine shows me abs coordinates and another shows relative (silly to me).
    Of course I appreciate absolute coordinates, I am used on it.
    Any parameter for that?
    Feb 2007
    314
    for your first new problem try parameter 18 bit 5 (6th from the right). But i cannot help you for the 2nd problem
    Jan 2004
    33
    Your second new problem is controled by Par# 0028, bit 0 (the first one on the right side)
    Mar 2006
    107
    Quote Originally Posted by samu View Post
    Thank you, that problem is solved!!!
    Quote Originally Posted by RODMAN View Post
    In my yellow OM book that parameter stands for :"On the program check screen, the absolute coordinates are disllayed."
    And it is set to 1.
    I need to change abs/rel in offset (tool length register) display
  1. Mach3 Strange behaviour
    By wellbuiltcabs in forum Mach Software (ArtSoft software)
    Last Post: 01-31-2008, 02:48 AM
  2. Strange behaviour of 10T
    By guhl in forum Fanuc
    Last Post: 12-11-2007, 04:28 PM
  3. Strange Chinese laser engraving behaviour
    By MicheleZicchino in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-08-2007, 02:12 PM
  4. VMC 15-XT strange behaviour
    By FinnCNC in forum Fadal
    Last Post: 03-27-2007, 05:03 PM
