Originally Posted by
JCMills
Tool setters for vertical cnc. I am trying to trace down a contact setter for our v-33 makino--one that is the simple large button about 7/8 diamter. The renishaw ts27r wont do, its design is fatally flawed, and the laser of course does not work well or at all in many circumstances. I do rapid prototyping molds and the tools have to blend. Of course nothing is as accurate as the spacer block method with the tool in the machine but a somewhat close contact setter is convenient for myself and others.. There is a company in Japan called metrol--but they are impossible to make contact with--they however have the basic concept of a cutter coming down on a round button... It was too bad about the laser--but they do not work well and CANNOT work well because of the WAY they work. Setting off line on the surface plate is not fast or accurate enough and is not cost effective for our application. The vision based setters are also not behoovious for our application.. My personal choice of course is the 1 inch spacer block method--since that truly is the last and final word....The various indicator setters or electonic light setters are somewhat cute--(but then you unleash a can of worms as far as shop logic.) (Problems setting the cutters can often metasticise and lead to disorietation and vertigo with running warm up programs and such.....) this is my first post after discovering this site.. thanks jc Motorola
