586,058 active members*
4,306 visitors online*
    Apr 2007
    27
    Bridgeport Interact 720 parameters
    We have a Bridgeport Interact 720 machining center that has a Fanuc 0-Mate controller on it. We have lost the parameters for it. We had all of the parameters backed up except for the 900's. From my understanding these are set by Fanuc. Does anyone have one of these machines? Would I be able to get the 900's parameters from it? Any help would be great.
    Matt
    May 2009
    26
    Interact 720 Par.
    I think we can make a trade. I need the ladder information from eo1 and eo2 Eprom chips. this will not cost you a cent. but if i get the information i need i will more than be happy and provide all the information you need.
    Besides from piratical experience, you will also need this information too, If these chips ever go bad in your memory Control board. if you are interested you can contact me at 1-810-429-3728, or 1-810-658-2380 or email thru this site
    Apr 2007
    27
    This machine has been fix and is up and running. What exactly do you need? I will see if I can help you out.
    May 2009
    26
    What I need is the Ladder Logic that's only supplied by Bridgeport. It is contained on the two Eprom chips in the rear of the machine on the Memory Board. We had a Chip Failure EO1 Eprom. This information on these chips can only be read and re-burned onto another Eprom, If yours ever fails you will be in my boat. They are not contained in any of the parameters, they actually contain what the machine is and what it does.
    What I proposed is Having Fanuc CNC come to your facility and/or Shop and pull the memory card, (Maintaining Your full Parameter listings) by backing it up onto there drive and (I will have them make a copy for your records) have them pull the EO1 & EO2 Eprom chips and burn copies of the chip. (I will also have them give you one set). and then replace them and reinstall all your system back to working condition. Plus you get to pick there brains on any issues while there their.
    I want to reiterate this: It will cost you NOTHING I just need you to let them do the work for me.
  1. BPT Interact S1 MK1 TNC 151 Parameters please?
    By swarf_rat in forum Bridgeport / Hardinge Mills
    Last Post: 06-16-2020, 01:09 PM
  2. Bridgeport Interact 520/Heidenhain TNC 155 initial parameters
    By jeromir in forum Bridgeport / Hardinge Mills
    Last Post: 07-28-2018, 10:40 AM
  3. Bridgeport Interact 412/Heidenhain TNC 250 initial parameters
    By pedrow in forum Bridgeport / Hardinge Mills
    Last Post: 09-26-2014, 08:11 AM
  4. interact 1 mk2 tnc 2500 parameters
    By markjackson in forum Bridgeport / Hardinge Mills
    Last Post: 06-29-2007, 01:05 AM
  5. HELP...interact 4 lost parameters
    By camarogod98 in forum Bridgeport / Hardinge Mills
    Last Post: 02-13-2007, 01:50 AM
