586,551 active members*
3,437 visitors online*
Thread: G76 CYCLE
    Feb 2007
    107
    G76 CYCLE
    BIG DEBATE IN SHOP,,,,, I NEED AN EXAMPLE OF A G76 CYCLE FOR A 1/4-18 NPT.
    3 GUYS HAVE 3 DIFFERENT METHODS OF USING THAT CYCLE.
    MITSUBISHI CONTROLLER
    THANKS.
    BAD DOG
    Jan 2008
    575
    I would P.M. Geof or APP, sorry I'm not much help. Robert
    Mar 2004
    1543
    I'll let you do the math on all the points. here's an instruction sheet for my control.
    'EXAMPLE G76 LINE 1 FOR 1/2" ROD 20 TPI
    'G76 P011060 Q50 R10
    'first two digits after P number of finish cut passes
    'second two digits after P number of leads to pull out/10, 10 is 1 lead
    'third two digits after P is tool tip angle, tool will infeed at 1/2 this angle
    'Q is minimum DOC cut in tenths, example 50= .0050 depth radius
    'R is DOC finish passes in tenths
    'S is optional spindle speed, spindle must be running with an earlier M3 M4 code
    'EXAMPLE G76 line two 1/2" rod 20 TPI .5" long 1 thou taper (Z 0 at start of thread)
    'G76 Z-.5 X.4567 P433 Q100 F.05 R.001
    'Z is end of thread Z value
    'X is final diameter of thread value; minor dia. on O.D., major dia. on I.D. (LH) threads
    'P is thread height in tenths, 433 is .0433 high, generally COS(infeed angle)*1/thread pitch
    'Q is depth of cut for first cut in tenths
    'F is feed per thread, 1/LEAD for US
    'R is for tapered threading difference in X from start to finish in Z
    -----G76
    The G0 or G1 move just before is important also. It determines start Z for thread and return plane, X, for next pass.
  1. g76 thread cycle
    By warcnc in forum G-Code Programing
    Last Post: 02-03-2013, 11:32 PM
  2. Threading cycle
    By chrisryn in forum Parametric Programing
    Last Post: 06-12-2008, 09:04 PM
  3. roughing cycle on ot-a
    By iancally in forum Fanuc
    Last Post: 06-03-2008, 03:05 PM
  4. G76 Boring Cycle
    By Gorrell in forum G-Code Programing
    Last Post: 01-25-2007, 10:22 PM
  5. How do I set Parameter 592 for G 83 Cycle
    By Farmer in forum G-Code Programing
    Last Post: 11-27-2004, 05:13 AM
