587,072 active members*
2,964 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > TB6560HQ-Stepping Motor Driver IC 3.5amp
Page 1 of 14 12311
Results 1 to 20 of 272
    Oct 2005
    36
    hi
    PWM Chopper-Type bipolar
    Schematic and pcb TB6560A whit protel dxp.
    Features
    • Single-chip bipolar sinusoidal micro-step stepping motor
    driver
    • Uses high withstand voltage BiCD process:
    Ron (upper  lower) = 0.6 Ω (typ.)
    • Forward and reverse rotation control available
    • Selectable phase drive (2, 1-2, W1-2, and 2W1-2)
    • High output withstand voltage: VCEO = 40 V
    • High output current: IOUT = HQ: 3.5 A (peak)
    FG: 2.5 A (peak)
    • Packages: HZIP25-P-1.27/HQFP64-P-1010-0.50
    • Built-in input pull-down resistor: 100 kΩ (typ.)
    • Output monitor pin equipped: MO current (IMO (max) = 1 mA)
    • Equipped with reset and enable pins
    • Built-in overheat protection circuit
    Attached Files Attached Files
    Feb 2005
    122
    thanks for info, could you please tell us from where did you get the TB6560 ?
    364
    I bought some from this guy:
    http://stores.ebay.de/Markus-Mechatr...QQftidZ2QQtZkm
    They aren't listed for the moment but you could ask if he can still deliver.
    Regards,
    Luc.
    Aug 2005
    25
    where can get he PCB to build the board ?
    I have 2 TB6560 here.
    Is a test video or picture available ?
    Best regards
    Chris
    364
    My boards
    Here's a picture of my DIY version, it's a double sided PCB.
    I couldn't find an easy way to design the PCB with decent size power tracks so I had to choose between a nice design with connectors etc. or something that should work, I did choose the second option and came up with a very small PCB with connectors for the power input but soldered wires for the motor connections directly on the board.
    I also had to slip the PCB between the pins of the chip.
    These have been used on 3 machines and they work very well, even at 2,5 Amp output only a small heatsink is needed, no active cooling like almost every other chip needs.
    There's also a German guy who made a design, here's the link:
    http://www.roboternetz.de/phpBB2/pri...=33986&start=0
    Regards,
    Luc.
    Aug 2005
    25
    Hi Luc,
    i know the german guy and i have contact via e-mail.
    The german version is not finished yet. He have some problems.
    Your design is very simple, that´s what i need.
    Is ist possible to get 3 PCB´s of your version ?
    Do you habe a part-list ?
    Thanks a lot.
    Bye
    364
    there are 2 versions of "my design".
    The first one has jumpers for all options (torque and decay control), these have been removed on the lastest version.
    I still have one problem: on the first version the motor is noisy (hissing) and completely silent on the second version, I don't know why:
    PCB design, the different type of current sense resistors I used or the removed option jumpers.
    I don't have pcb's of the second version but have a few of the first one.
    I really need some time to investigate the noise disappearence by swapping components.
    Which motors do you have, output current required? Also wich power supply do you intend to use?
    My design is really simple but needs an optically isolated BOB (designed my own matching these drivers :-) ).
    Are you in a hurry? : I will make a new batch of the second version in the near future but can't say when.
    Regards,
    Luc.
    Aug 2005
    25
    thanks for the answer.
    I can wait and will check the thread in the next time.
    Bye
    Dec 2005
    8
    Hi all,
    Good jobs, any news of the latest version?
    1) Does Tb6560AHQ microstepper drive with any step error?
    2) Can Tb6560AHQ work without back emf dumping diode?
    I'm looking forward to your reply.
    khoo
    Nov 2008
    10
    The Data Sheet shows built in diodes
    The TB6560 data sheet shows built in free-wheeling diodes. It doesn't say if the external diodes are needed or not. Diodes are cheap. I think I would add them just to be safe.
    Cheers,
    Gridley
    Feb 2009
    5
    I have used the smaller 2Amp parts TA8435 for years on my X1 CNC conversion. No re wheeling diodes needed, parts hardly get hot, motors get hotter. I also have motor hissing on the TA8435 controller but only in the Z axis motor? Very ugly design, all hardwired on vero board no pcb design.
    Just got my 1st prototypes of new opto isolated TB6560HQ quad PCB.
    Made the mistake of designing in SMD current feedback resistors.
    I think I will use though hole resistors for production units.
    Designs are quad versions of my single PCBs, 1.5Amp A3983 and 3Amp TB6560 micro steppers. The A3983 pcb will plug onto the propeller prototype PCB to drive the 17 size baby mill.
    Going to use the Quad TB6560 for a 23 size router design.
    I still have jumpers on mine, need to use them for real to find out what settings work best. Still need a few more parts before I can test these boards. Should know in a week or so how may changes will be needed before designing for production.
    I am open for suggestions.
    Regards
    Gavin
    www.hexkeycnc.com
    364
    Finally found some time to continue, I made some new PCB's a while back and used 2 different styles of wirewound resistors. And the hissing is back.
    I just replaced them with the "non hissing ones" without changing anything else and it's dead silent.
    So I need to find non-inductive ones, a quich search at different suppliers wasn't succesfull, they are either too big (3W) or SMD ones wich are just underrated.
    Anyone knows a good supplier?
    Quote Originally Posted by khootk View Post
    Hi all,
    You are talking about the newer A version wich can do 1/16 microstepping, I didn't use this one yet.
    I don't have a good setup to test for step error, external diodes are not needed, they are sometimes used on some types of chips to take these currents out of them and thus reduce the chip's heat.
    The TB has a real low RDS and also uses synchronous rectification, these require minimal heatsincking.
    Quote Originally Posted by HexkeyCNC View Post
    Why is SMD a mistake? Or can't you find the correct value and wattage?
    Regards,
    Luc.
    Mar 2009
    Good evening,
    Lucas i have a question about your schematic, R7,8,9 are look to have a value of RES2, how do you determine the value of the resitors?
    Good job on your PCB by the way.
    Thanks for your help Dan
    364
    Dan,
    thats not my schematic.
    Attached is the one I am using on 2 machines (ver 1).
    I have the optocouplers on the BOB.
    Regards,
    Luc.
    Jul 2005
    27
    Quote Originally Posted by lucas View Post
    Could any body tell me if there is any possibilitie to add any type of Vref in orther not to chage the 2 Rsences any time I want to use diferent motor current ? As have Allegro (sanken) or ST Ic's.Like PIN 10 in TA8435HQ
    _____________________________________________
    Hare Krishna Hare Rama
    Jul 2005
    27
    IC vref
    Could anyone tell me if there is any possibilities to add any type of Vref in order not to change the 2 Rsences any time I want to use different motor current ? As have A3986, L297 or TA8435HQ ( PIN 10 ) IC's
    364
    Sorry for the late reply.
    The absence of a Vref input is indeed a disadvantage for this chip.
    It's very big advantage is the price: 4.2 US$ for a 1/16th microstepping chip at digikey.com.
    But you can use the 2 torque inputs to reduce the current output.
    I didn't have issues with this, the drivers were build to match the motors when building a machine, if stronger motors are needed after tests then indeed the resistors have to be altered, however this is quite easy compared to the motor change, mechanical changes, bigger power supply etc...
    One option isn't possible: one driver cabinet for different machines like you can do with Gecko's where the current resistor is incorporated in the motor cables.
    Jun 2003
    3312
    The TBQ6560 is a nice little chip, I've been pleased with how it performs. Yes it suffers from being less flexible on setting currents. One point I would make, it's very important to use a low esr capacitor on VM, and a decoupling capacitor very close to the chip for VM supply pins.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    364
    Phil,
    do you have pictures of your design using this chip?
    PCB layout for this one isn't really easy.
    I have used SMD (low inductive) current sense resistors on my latest build and the motors are dead silent. They are 0.5 ohms each and the pcb has 3 locations for each coil, so installing one resistor gives a 1 Amp drive, 3 makes a 3 amp drive.
    Regards,
    Luc.
    Jun 2003
    3312
    Here is one version. Sense resistors are on the bottom of the pcb. SMD 2515 2W.
Page 1 of 14 12311
  1. THB6064H(4.5A)-Stepping Motor Driver IC 4.5amp
    By NASR1 in forum Open Source Controller Boards
    Last Post: 10-03-2014, 12:52 AM
  2. Stepping Motor Driver IC THB6064H
    By lihaijiang in forum Engraving Machines
    Last Post: 07-07-2009, 03:49 AM
  3. THB6064H stepping Motor Driver IC4.5A
    By lihaijiang in forum News Announcements
    Last Post: 06-22-2009, 03:29 AM
  4. Stepping Motor Driver
    By MR MOTION in forum Stepper Motors / Drives
    Last Post: 05-17-2009, 06:13 PM
  5. 80V 6A Micro stepping Motor driver
    By eded59 in forum Stepper Motors / Drives
    Last Post: 07-31-2007, 03:43 AM
