586,104 active members*
3,449 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > Material need for insert type tool holders
    Oct 2006
    8
    hi;
    I need help for making indexable carbide inserts type endmills body, what type of material is best for making such tools.
    if some one has an idea about that kindly share with me.
    thanks.
    Arif
    Dec 2006
    5
    i guess you sould you high carbon content steel alloys, or 4140 mr. Arif
    Oct 2008
    6
    use?
    If it's something to just get you out of trouble, most any steel will work. If you are looking for longer life then 4140 or 8620 or similar would give you good results. A bit more pricey but if you had some 17-4, 13-8, 455 or 465 stainless steel drops laying around they would work as well.
    Jan 2007
    210
    4140 pre-hard
    You can always spot the pioneers -- They're the ones with the arrows in their backs.
    Feb 2007
    1084
    They are right. I just made lathe tool holders from KennaMetal prints (out of catalog stuff), 4140 prehardened to 30 rockwell C.
  1. GS Tool Holders
    By big_mak in forum CNC Tooling
    Last Post: 03-31-2011, 06:58 PM
  2. x4+ Tool holders
    By Martin Long in forum Syil Products
    Last Post: 06-21-2009, 07:07 AM
  3. Tool Insert Help
    By Cartierusm in forum Uncategorised MetalWorking Machines
    Last Post: 11-21-2007, 03:05 PM
  4. bt and ct tool holders
    By reedmiles in forum MetalWork Discussion
    Last Post: 11-16-2007, 05:39 AM
  5. tool holders
    By barnesy in forum MetalWork Discussion
    Last Post: 07-08-2006, 09:54 AM
