586,094 active members*
3,996 visitors online*
Results 1 to 10 of 10
    Sep 2008
    22
    problem x axis
    good evening,
    I have a problem with the x-axis when you move in fast moving x only moves with a preview of 495mm/min that only happens in a positive sense
    in advance thank you very much
    jorge
    May 2006
    64
    What is your Fanuc model ?
    Your machine is new machine or used machine?
    Sep 2008
    22
    MACHINE KIA H50
    FANUC 18MC
    CENTER MACHINING HORIZONTAL
    KIA H50
    MODELO 2000
    4 EJES
    2 PALLETS
    PARAMETERS WILL BE OR ELECTRONIC
    Aug 2006
    98
    Jorge,
    Check if the signal X6.5 stay in 1. If yes, the limit switch of reference is active. You need fix that.
    Daniel
    Sep 2008
    22
    friend thank
    friend thank you for your response,
    BUT THE TRUTH not know WHERE CAN I SEE THE SIGNAL x6.5
    Thank you in advance
    JORGE
    May 2007
    1003
    Try SYSTEM, PMC, PMCLAD, type in X6.5, press Search. Don't know if you need the .5. I am only a lowly lathe programmer.
    Aug 2006
    98
    Jorge,
    Like G-codeguy said, this is on way. But there is more one. PRESS SYSTEM > PMC > PMCDGN > STATUS. Type X6.5 and press NO. SRH. And remenber. Hyundai-Kia machines has the ladder open. It´s possible you edit that.
    Good Luck,
    Daniel
    Sep 2008
    22
    problem x axis feed rate
    Good morning,
    Friend apology but the truth do not know if I understood.
    is that I am Colombian and I do not speak or write English, but the problem is that the X-axis moves slowly in a positive sense and in the negative moves fast
    because if the solution to that problem is no excuse but to understand
    as publishers that parameter in the machine?
    jorge
    Sep 2008
    22
    I found this following the path you told me.
    X0006 5
    exdexl
    ME THAT INDICATES THAT?
    Aug 2006
    98
    Jorge,
    The limit switch of reference of the X axis are broken. Check that. The signal must stay in 1 when the axis is out of reference position.
    Daniel
  1. problem x axis
    By jlviloria in forum Hyundai Kia
    Last Post: 09-24-2008, 03:28 PM
  2. TC-22 z axis problem
    By gmagnuson in forum Bridgeport / Hardinge Mills
    Last Post: 03-14-2008, 03:36 PM
  3. z axis problem?
    By automatic in forum Open Source CNC Machine Designs
    Last Post: 12-10-2007, 03:04 PM
  4. Z Axis problem
    By studysession in forum Mach Software (ArtSoft software)
    Last Post: 05-06-2007, 12:06 AM
  5. z axis problem
    By UMASSREHAB in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-29-2006, 11:45 PM
