586,504 active members*
3,405 visitors online*
IndustryArena Forum > MetalWorking > Welding Brazing Soldering Sealing > Airco 300 Heliwelder IV Need to know Proper wiring
    Sep 2008
    I have a old Airco 300 Heliwelder IV machine. I have just ordered a new reactor pwb for replacement and apprehensive to power the unit up. I need to know what color wires go to the 25 Amp bridge rectifier mounted directly above the reactor board. There are four wires, colors are blue, white, red & black. I know the white & blue go to the AC terminals. Does anyone know the correct wiring for the red & black leads? I have a picture of the wires in question. If anyone knows some type of an answer, I would greatly appreciate your comment or suggestions.
    Thank you for your time.
    Attached Files Attached Files
    Jul 2008
    24
    Bridge wiring
    Black is positive+ and red is negative-, just backwards of what you would think.
    Sep 2008
    Thank you for your reply. I just needed to confirm the wiring before I power the unit up. The picture shows what you have said. This must have been a mistake at the factory during production or it must have been made overseas.
    Thanks again!
  1. AIRCO Heliwelder IV
    By machinewbie in forum Welding Brazing Soldering Sealing
    Last Post: 03-06-2020, 02:56 PM
  2. Proper use of THK rails
    By mdierolf in forum DIY CNC Router Table Machines
    Last Post: 08-19-2008, 03:46 AM
  3. CNC Retrofit Plate burner Questions ( Airco Servograph )
    By Rebar Grove in forum Waterjet General Topics
    Last Post: 07-25-2007, 02:26 PM
  4. Proper grounding
    By monte55 in forum Xylotex
    Last Post: 12-05-2006, 08:09 PM
  5. Proper Use of TEACH?
    By squarewave in forum CamSoft Products
    Last Post: 06-25-2005, 01:30 AM
