if someone could help me, i need a post processor for surfcam to mach3 for 4 axis work. my friend is coming over to work with me next weekend, he has surfcam at his business. hes bringing it with him to help me.
http://www.machsupport.com/forum/index.php
Post there, you will get the best answer, and probably the fastest answer. Good luck!
no luck there.
Would you please post the GM code of Mach3 4 Axis, especially the Tool Change, First Tool Change, Start up Sequence, End Sequence, Cycle code ... etc.
I think someone could help you!
if anyone could help me i would appreciate it. i think its based on a fanuc control code
need to post a program like sinderal said, with the G and M codes of what he specified.. that txt file you posted doesn't help..
Just when you thought you had it all figured out, all hell breaks loose..
