586,069 active members*
3,361 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > Tapping head or rigid tapping
    Nov 2007
    45
    I am trying to find out what people are using to tap. I am tappinga very small hole 0.0400 and then using a 1.2mm tap. Has anyone here used a tapping head like the one Tormach sells. Any info would be helpful
    Aug 2007
    26
    I have been using the Tapmatic 50x on the Syil SX3 with success. Even with the small collet though you can only go down to shank size of 3.5mm.
    According to their web site their 30x model will take shanks down to just over 1mm but then limits you on larger sized taps.
    The system works very well but the unit and collets are expensive unless you can pick them up second hand. I have found this unit works better than the built in tapping function of the SX3 which often stripped threads for me.
    (http://www.tapmatic.com/pdfs/46449_2..._rev'd.pdf)
    Oct 2006
    975
    I have a Buck tapping head to use on up to 1/2 inch taps, but I really like the feel and ease of setup of the Procunier tapping heads. You can find used tapping heads often on eBay selling at reasonable prices. That's where I got my Buck tapping head at a very good price. I have used the Tapmatic tap heads at work and they work fine, but I prefer the Procunier brand as the collets are size specific and the tapping head is more compact.
    Regards,
    Regards,
    Wes
  1. Rigid tapping help
    By Genguy in forum Fanuc
    Last Post: 12-08-2015, 02:54 PM
  2. Replies: 24
    Last Post: 05-01-2014, 07:02 AM
  3. Very rigid tapping
    By Vern Smith in forum Haas Mills
    Last Post: 06-14-2007, 11:52 PM
  4. Rigid tapping or tapping head
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 09-24-2006, 06:08 PM
  5. tapping head vs hand/cordless tapping machine....
    By InspirationTool in forum Uncategorised MetalWorking Machines
    Last Post: 09-13-2005, 02:10 AM
