I have crashed with the upper torret in B axes. The turret has rotated for around 10 degrees. Is it possible to rotate the turret with wheel and how?
look at your electric door, if there is a blue book with the machine
in the book stands KEEP RELAIS, there is prob. one for manual turret turing.
some versions you can rotate the turret when its powered up, rotate the turret and hit the emerency button, turret will stand out and can be hand turned.
turn the turret bij hand to a position, set the promotion driver to the same position as your turret is. and that should be fixed.
you also need to line up the turret again, and check the b-axis, cut a piece of metal and check it's not tapered
