My name is Tony Mitchell and I am the owner of www.mitchellindustrial.com where we specialize in rebuilding ball screws. We can turn around a ball screw in 24 to 48 hours and we can also do onsite repairs as needed. All of our ball screw repair work is fully guaranteed for up to 36 months from the install date.
I can quote you over the phone if you can provide the following information:
Approximate length & diameter of your ball screw.
Single or double nut?
External return tubes, or internal?
What is the problem with your screw? Noisy? Loss of tolerance? Crashed? Please be specific for an accurate quote.
I can also repair the bearing journals if they are worn (grind, chrome & grind) or snapped off.
Thank you
