586,103 active members*
3,482 visitors online*
    Jun 2008
    23
    stepper step rate
    how many step/sec considered as slow, medium, and fast step rate?
    May 2008
    14
    Typically we don't use steps/sec for anything. The number of steps/in or steps/mm is a constant value that needs to be calculated. For actual speeds we use either inch/min or mm/min.
    I would consider 2 revolutions per second slow, 10 revolutions per second medium and 50 revolutions per second as fast.
    Mariss
    May 2007
    380
    xinzc28, Keep in mind that stepper motors have more power when they are running slower. As the step rate rises, the power will drop to the point the motor will stall.
    John
  1. Max Step Rate (or RPM) for 23-200-DS
    By Don Peterson in forum Hobbycnc (Products)
    Last Post: 11-03-2005, 12:18 AM
  2. MACH3 Maximum Step Pulse rate
    By Ken_Shea in forum Mach Software (ArtSoft software)
    Last Post: 09-21-2005, 02:14 PM
  3. Accel Step Rate Hz Setting
    By Sanghera in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-30-2005, 01:10 PM
  4. Choosing a step rate?
    By Rhodan in forum CNC Machine Related Electronics
    Last Post: 04-26-2004, 03:42 PM
  5. Whats the max step-rate of Mach 1?
    By cncadmin in forum Mach Software (ArtSoft software)
    Last Post: 04-24-2003, 01:41 AM
